查看: 68|回复: 4
Peterbilt fuel caps
 楼主| 发表于 2024-6-12 08:48:18 来自手机 | 显示全部楼层 |阅读模式
{"text":"Does anyone else have problems with Peterbilt’s flip lever fuel caps? Mine last a couple months then they leak again.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2024-6-13 22:46:49 来自手机 | 显示全部楼层
2459412 发表于 2024-06-12 01:12:34 Depends how are the gaskets, orings? They get old and need to be replaced. How are the necks? The necks get worn and scratched and need to be filed flat with a file. How are the vents? are they plugged? How are the fuel lines especially above the trans? they get cracked and pull air or make the pump cavitate and air is put into tank. \nLots of reasons for your issues.Try a walmart bag under the cap and see if it stops.
","text":"They also have replacement caps called leak defender they coast a lot but money well spent","replyToPid":480838}
 楼主| 发表于 2024-6-12 10:33:07 来自手机 | 显示全部楼层
","text":"Thanks for the help buddy!","replyToPid":480838}
发表于 2024-6-12 09:12:34 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Depends how are the gaskets, orings? They get old and need to be replaced. How are the necks? The necks get worn and scratched and need to be filed flat with a file. How are the vents? are they plugged? How are the fuel lines especially above the trans? they get cracked and pull air or make the pump cavitate and air is put into tank. \nLots of reasons for your issues.Try a walmart bag under the cap and see if it stops."}
发表于 2024-6-14 00:15:40 来自手机 | 显示全部楼层
1658421 发表于 2024-06-13 14:46:49 They also have replacement caps called leak defender they coast a lot but money well spent
","text":"Yeah I forgot about those. I almost bought some for my freightshaker. I used rubber coolant plugs to stop.mine from leaking.","replyToPid":480861}
GMT+8, 2026-4-15 11:45 , Processed in 0.120091 second(s), 24 queries .
