查看: 134|回复: 15
ilog // Truck drivers when you loading or unloading do you put your ilog on off duty or on duty ?
 楼主| 发表于 2024-6-8 04:14:53 来自手机 | 显示全部楼层 |阅读模式
{"text":"Truck drivers when you loading or unloading do you put your ilog on off duty or on duty ?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2024-6-8 12:15:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"half hour on duty then switch to off duty","replyToPid":0}
发表于 2024-6-9 09:11:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Technically you should go on duty for about 5 minutes and flag a delivery, then you can either go Sleeper or Off Duty. If you forget don't sweat it to much DOT misses that part, but do try to remember to update your bol #'s.","replyToPid":0}
发表于 2024-6-8 04:49:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"DOT says 'on duty.' But they're never going to know... 😉","replyToPid":0}
发表于 2024-6-13 23:11:10 来自手机
2187725 发表于 2024-06-12 17:48:53 Apr 30, 2018 — According to FMCSA regs, all time spent at a dock either loading or unloading is supposed to be logged as on duty
","text":"That is such crap because you can sit at the dock for hours at some places where you aren't allowed inside to help with anything. If I ain't working I'm off duty on my paper logs. I mark 15 minutes on duty for checking in and backing up to the dock and 15 minutes off duty. Never had a DOT officer bat an eye.","replyToPid":480850}
支持 2 反对 0
发表于 2024-6-13 01:48:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"Apr 30, 2018 — According to FMCSA regs, all time spent at a dock either loading or unloading is supposed to be logged as on duty","replyToPid":0}
发表于 2024-6-8 21:24:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"you could do off duty but make sure you on duty if your BOL is time stamped.","replyToPid":0}
发表于 2024-6-13 04:30:28 来自手机 | 显示全部楼层
","text":"Disconnect from trailer and you are no longer laden. Then can legally be in sleeper or off duty.","replyToPid":480850}
发表于 2024-6-9 21:03:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"I go on duty 15 min then off duty for the entire evolution...and if u at Costco or Safeway,,,,ALL DAY LONG..","replyToPid":0}
发表于 2024-6-11 08:57:35 来自手机
{"replyTo":"","text":"Wth is an ilog?","replyToPid":0}
支持 1 反对 0
发表于 2024-6-8 05:16:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"If I'm doing it on duty. If they are off duty and depending on length of time, switch to sleeper berth.","replyToPid":0}
发表于 2024-6-8 07:10:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"off duty","replyToPid":0}
GMT+8, 2026-4-18 12:29 , Processed in 0.139534 second(s), 24 queries .
