查看: 58|回复: 2
tandems all the way in front
 楼主| 发表于 2024-5-30 20:12:54 来自手机 | 显示全部楼层 |阅读模式
{"text":"is it a fine or points if weight is too much at bridge law 40 or 41 from kingpin so we have to balance the load at Drive tires from 36000 to 34000 by shortening distance.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2024-5-31 01:07:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"Buy yourself a motor carrier's road atlas.\nit has these great pages thar tell you each state weight restrictions, limits,bridge clearance etc.........","replyToPid":0}
发表于 2024-5-31 22:47:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"As far as I know there aren't rules against tandems being all the way forward. The rules generally limit for far BACK the tandems can be.\n\nThe caution with the tandems all the way forward is trailer swing. The trailer always rotates at the halfway point between the tandems. You can easily sideswipe things with the back of the trailer when the tandems are all the way forward.","replyToPid":0}
GMT+8, 2026-4-15 11:46 , Processed in 0.074798 second(s), 25 queries .
