查看: 16|回复: 1
missing screws on prox sensors
 楼主| 发表于 2024-5-25 22:18:56 来自手机 | 显示全部楼层 |阅读模式
{"text":"this is what that does. it registers an object at 1 ft randomly forcing you to drive off the cruise to override the deep engine brake. you have to accelerate on an incline. you can't move unless you are acceleration over the engine brake. that's a life threatening tamper the error is random. my guess is because flips forward and sees the ground. did this happen to you at x large company? or other strange errors just before an accident? I'm accident free but that was a hard few months and I believe there is equipment tampering. I switched to lease to stop my harmful tampers and it started again.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
 楼主| 发表于 2024-5-25 22:50:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"you accelerate on the DESCENT as well. it puts your rpm over limit you have no engine brakes.","replyToPid":0}
GMT+8, 2026-2-5 11:50 , Processed in 0.051089 second(s), 23 queries .
