查看: 19|回复: 6
wonky navigation
 楼主| 发表于 2024-5-22 01:43:37 来自手机 | 显示全部楼层 |阅读模式
{"text":"is anyone else noticing g the navigation\ntaking you off route o ly to bring you right back o. the same road only miles down the the road through town. or giving you routes through back roads, basically the long off route route to your destination instead of \"go straight and turn\"!!!","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2024-5-23 21:40:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"Never happens when using an atlas.","replyToPid":0}
发表于 2024-5-22 07:21:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes it has been really bad about that lately also changing route in the middle of destination","replyToPid":0}
发表于 2024-5-23 19:05:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"🤷🏻‍♂️ Seems to be a problem with every navigation app or hardware.\n\nIn some cases the route might be 42-feet shorter and you did ask for shortest route. Other times the program clearly added 2+2 and got Lutefisk.","replyToPid":0}
发表于 2024-5-29 18:04:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes, takes you off the \"I\" around the block and back on the \"I\". I used to fall for it. Now I check it before I exit. really pisses me off.","replyToPid":0}
发表于 2024-7-1 03:46:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yeah, this happened to me going through the Harbor tunnel luckily I used to live in Baltimore. I was very familiar with the area and I knew it was wrong so I just kept going lol","replyToPid":0}
发表于 2024-7-3 08:17:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"Y. E. S. 🙁","replyToPid":0}
GMT+8, 2026-2-4 06:19 , Processed in 0.114456 second(s), 24 queries .
