查看: 17|回复: 3
good ways to tell if you're a PROFESSIONAL driver or an imposter
 楼主| 发表于 2024-5-19 07:15:16 来自手机 | 显示全部楼层 |阅读模式
{"text":"if your vehicle is loud enough to cause hearing damage inside another person's vehicle,  you are not a professional . * I think this might be my reefer today. so sorry. \n\nif you save your grocery bags for your number 2 instead of fill it with toilet paper, you are not a professional. \n\nif you spend more time tampering with other people's vehicles than inspecting your own, you are not a professional. \n\nif you care more about other people's footwear than your own headlights, you are not a professional.\n\nif you think I should move my vehicle off the road so you can safely pass, you are not a professional.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2024-5-19 09:40:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"1. Loud pipes save lives!\n2. I use mine only for number 3s!\n3. I will pull your pin or flatten tires if you mess with me!\n4. Real truckers don't wear flip-flops!\n5. You are not a left lane outlaw!\nDefinitely a professional driver!","replyToPid":0}
发表于 2024-5-19 10:56:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"Tampering with other people's vehicles? People do that? Just curious","replyToPid":0}
发表于 2024-5-19 11:15:58 来自手机 | 显示全部楼层
2405505 发表于 2024-05-19 02:56:24 Tampering with other people's vehicles? People do that? Just curious
","text":"Yeah they do. \n\nPeople will pull kingpin release arms so the driver drops their trailer when they pull out - pro-tip ALWAYS check your kingpin release when you get back to your truck.\nEvery. Single. Time.\n\nPeople will undo hood latches so you're hood falls open when you slow down.\n\nThere's a simple way to disable someone's trailer brakes - not gonna say how on a public forum. \n\nPeople turn off reefer units.","replyToPid":480583}
GMT+8, 2026-2-5 12:58 , Processed in 0.061104 second(s), 24 queries .
