查看: 58|回复: 2
Truck scale calculator removal from iOS store
 楼主| 发表于 2024-5-14 06:54:30 来自手机 | 显示全部楼层 |阅读模式
{"text":"I just noticed that the Truck Scale Calculator by Bruce Fraser has been removed from the iOS store. It helped you figure out how many pins you needed to move your tandems. \n\nAre there any alternatives on the App Store that I’m not aware of. All the other apps I found require a link to a different company to use.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2024-5-17 15:33:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"truckers slide calculator  by solutions for semis is what i use","replyToPid":0}
发表于 2024-5-18 11:03:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yeah, simple math. Measure the distance between pin center to center, and that will tell what pins each one moves the weight.","replyToPid":0}
GMT+8, 2026-4-17 02:19 , Processed in 0.073111 second(s), 25 queries .
