查看: 19|回复: 4
Body of a trucker found in his own truck.
 楼主| 发表于 2024-5-9 08:16:03 来自手机 | 显示全部楼层 |阅读模式
{"text":"Ontario Police been searching him from past 2 weeks. They said they assigned many resources and personnel for extensive search. But they never searched his own truck.\n\nThis is today's policing. Wow!","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
 楼主| 发表于 2024-5-9 09:23:50 来自手机 | 显示全部楼层
2407394 发表于 2024-05-09 01:04:07 Genius read the story again.  Better yet find a 5th grader to read it to you.  He was found in his trailer. His trucking company is responsible for not checking trailer.
","text":"Edit it again after 2 minutes. You sound like a psychopath. You need some help.\n\n Anyhow, Trailer was attached to the truck. His truck was in Ontario and trucking company in Newfoundland. They moved trailer there after 2 weeks, that's when they found the body.","replyToPid":480434}
回复 支持 4 反对 5
发表于 2024-5-9 21:48:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"This is A classic case of multiple failures and everyone gets to blame someone else for the failure 😞","replyToPid":0}
发表于 2024-5-9 09:04:07 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Genius read the story again.  Better yet find a 5th grader to read it to you.  He was found in his trailer. His trucking company is responsible for not checking trailer."}
回复 支持 2 反对 2
发表于 2024-5-10 09:16:18 来自手机
2405505 发表于 2024-05-09 01:23:50 Edit it again after 2 minutes. You sound like a psychopath. You need some help.\n\n Anyhow, Trailer was attached to the truck. His truck was in Ontario and trucking company in Newfoundland. They moved trailer there after 2 weeks, that's when they found the body.
","text":"Poor poor baby. Get momma to change your diaper","replyToPid":480435}
支持 1 反对 2
GMT+8, 2026-2-5 12:59 , Processed in 0.063663 second(s), 24 queries .
