查看: 73|回复: 7
Rust on frame A older hand told me this long time ago
 楼主| 发表于 2024-4-28 23:04:55 来自手机 | 显示全部楼层 |阅读模式
{"text":"What do some of you drivers use to combat rust on the frame of your rig.. I’ve been using a hard wire brush to scrape and used motor oil for years seem to work keep the rust from spreading just curious what others use if anything. 🚶🏾‍♂️","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2024-4-29 15:20:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ospho - get from Amazon.  scrape of the rust and just spray it on. converts the rust on a chemical level.  we used it offshore on stele vessels permanent fixfor rust. JUST DON'T GET IT ON YOU, wear nitrile gĺoves","replyToPid":0}
发表于 2024-4-28 23:45:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"I got some old cars. I restore in my off time. I buy rust encapsulate  From a company called Eastwood.  it works very well. Follow instructions.  Then apply good coat of paint over","replyToPid":0}
 楼主| 发表于 2024-4-29 15:47:00 来自手机 | 显示全部楼层
1060944 发表于 2024-04-28 15:45:31 I got some old cars. I restore in my off time. I buy rust encapsulate  From a company called Eastwood.  it works very well. Follow instructions.  Then apply good coat of paint over
","text":"Thank you looking for new ideas.🚶🏾‍♂️","replyToPid":480274}
 楼主| 发表于 2024-4-29 15:51:21 来自手机 | 显示全部楼层
2245975 发表于 2024-04-29 07:20:35 Ospho - get from Amazon.  scrape of the rust and just spray it on. converts the rust on a chemical level.  we used it offshore on stele vessels permanent fixfor rust. JUST DON'T GET IT ON YOU, wear nitrile gĺoves
","text":"Thank you I’ll check it out. 🚶🏾‍♂️","replyToPid":480285}
发表于 2024-5-1 04:13:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"I heard people use a mixture of car oil, coke soda, and transmission oil. good luck","replyToPid":0}
发表于 2024-5-1 04:18:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"I heard people use a mixture of car oil, Coca-Cola soda, and transmission oil. good luck","replyToPid":0}
发表于 2024-5-1 07:24:46 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Leave fuel caps off and let the diesel fly, and it will stop it from rusting.Salt and water will bead right off, hahahaha.\nI have found over the years regularly washing the truck, and you will have very little rust issues. The little you have if doing that cheap flat balck paint from Home Depot  or Lowe's over the top works great, and it's cheap.\nI never liked the oil mixture stuff because I have to do my own maintenance. It's awful to crawl around and get that all over you."}
GMT+8, 2026-4-17 02:18 , Processed in 0.084522 second(s), 24 queries .
