查看: 23|回复: 4
I-20 CLOSED IN BOSSIER CITY
 楼主| 发表于 2024-4-26 04:31:20 来自手机 | 显示全部楼层 |阅读模式
{"text":"I -20 is closed to semi trucks for construction on it!   \nThe signage is small and only light at night. \nThey are handing out tickets and pulling trucks over. You have to use the 220 loop around it. \nAt the construction area it’s only 7’ wide!","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2024-4-26 07:43:10 来自手机 | 显示全部楼层
2237663 发表于 2024-04-25 22:28:12 Always go bypass in Shreveport. it's a \"little\" smoother road anyway. Also, if you were not distracted and trucker pathin, you would see many signs that say take the bypass. Or you  can't read english.
","text":"20 thru Shreveport is terrible.  I always do bypass","replyToPid":480177}
发表于 2024-4-26 06:28:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"Always go bypass in Shreveport. it's a \"little\" smoother road anyway. Also, if you were not distracted and trucker pathin, you would see many signs that say take the bypass. Or you  can't read english.","replyToPid":0}
发表于 2024-5-2 01:37:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"You’re a rookie, sailing the signage small.  Maybe if you paid attention to the road & stayed off your cell phone, you’d know what was going on.","replyToPid":0}
发表于 2024-4-27 09:12:12 来自手机 | 显示全部楼层
1060944 发表于 2024-04-25 23:43:10 20 thru Shreveport is terrible.  I always do bypass
","text":"Yeah that must be one of the roughest stretches in a while. Not sure what they spend their road tax on. Hahaha.","replyToPid":480179}
GMT+8, 2026-2-5 17:13 , Processed in 0.063787 second(s), 24 queries .
