查看: 541|回复: 7
Ticket for drive in parkway
 楼主| 发表于 2024-4-17 13:07:01 来自手机 | 显示全部楼层 |阅读模式
{"text":"Good afternoon. Tell me, please, I accidentally drove onto the parkway, I was issued a fine. I have a commercial pickup truck with a trailer, what kind of fine can I get in court? Has anyone encountered anything like this?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2024-4-18 02:54:00 来自手机 | 显示全部楼层
2417974 发表于 2024-04-17 17:20:45 This was the first violation. 330 Route 376 Hopewell Junction NY 12533\nI don't have a CDL, just a regular E license, an empty pickup truck with an empty 36fit trailer
","text":"Oh no big deal probably $250 don't do it again the fines go up after each conviction.","replyToPid":480083}
发表于 2024-4-18 10:03:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"@dmeitrevdanill - I think a 36ft trailer requires a CDL-C. I think one of the categories for a class C CDL is small trucks (e.g. Your Pickup) towing a trailer greater than some length(I think over 25ft but not sure). .\n\nIf they didn't ticket you for that I'm not sure your WANT to go to court lest they discover the additional violation.\n\nI'd find out if you should have a CDL C and get one before they zap you for that.","replyToPid":0}
 楼主| 发表于 2024-4-18 05:12:39 来自手机 | 显示全部楼层
2237663 发表于 2024-04-17 18:54:00 Oh no big deal probably $250 don't do it again the fines go up after each conviction.
","text":"Thanks🙏","replyToPid":480087}
发表于 2024-4-20 23:34:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you have a DOT number on your pickup or van, New York would like to speak to you. Landscapers, roofing companies, plumbing companies, etc. are all available for a thorough meeting with NY DOT. Being below CDL guidelines doesn't enter into the equation. Disregard the perfection of a previous responder.","replyToPid":0}
 楼主| 发表于 2024-4-20 09:50:02 来自手机 | 显示全部楼层
665190 发表于 2024-04-18 02:03:42 @dmeitrevdanill - I think a 36ft trailer requires a CDL-C. I think one of the categories for a class C CDL is small trucks (e.g. Your Pickup) towing a trailer greater than some length(I think over 25ft but not sure). .\n\nIf they didn't ticket you for that I'm not sure your WANT to go to court lest they discover the additional violation.\n\nI'd find out if you should have a CDL C and get one before they zap you for that.
","text":"As far as I know, CDL is only required to drive trucks with a load capacity of more than 26,000 pounds","replyToPid":480089}
 楼主| 发表于 2024-4-18 01:20:45 来自手机 | 显示全部楼层
2237663 发表于 2024-04-17 15:14:58 Depends on which parkway? which state? How much weight were you? How many times have you been caught? From now on, you should not blindly follow your gps. This was not an accident. Every single parkway get on ramp has  huge signs say NO TRUCKS ON PARKWAY. If it says no trucks, that means any combination over 10000 lbs
","text":"This was the first violation. 330 Route 376 Hopewell Junction NY 12533\nI don't have a CDL, just a regular E license, an empty pickup truck with an empty 36fit trailer","replyToPid":480079}
发表于 2024-4-17 23:14:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"Depends on which parkway? which state? How much weight were you? How many times have you been caught? From now on, you should not blindly follow your gps. This was not an accident. Every single parkway get on ramp has  huge signs say NO TRUCKS ON PARKWAY. If it says no trucks, that means any combination over 10000 lbs","replyToPid":0}
GMT+8, 2026-4-16 03:14 , Processed in 0.100456 second(s), 25 queries .
