查看: 19|回复: 5
Cargo theft around Chicago
 楼主| 发表于 2024-4-9 09:06:53 来自手机 | 显示全部楼层 |阅读模式
{"text":"Drivers beware. Thieves are breaking into trailers at truck stops and rest areas all around the Chicago area. Lincoln oasis on I-80 south holland. TA exit 112 in Morris, IL. Pilot exit 112 in Morris, IL. Loves exit 116 in Morris, IL. Pilot in Minooka, IL.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2024-4-9 09:42:27 来自手机
{"replyToPid":0,"replyTo":"","text":"Most  likely baboons the chi natives who didn du nuffin. Good boys with their life together."}
支持 3 反对 1
 楼主| 发表于 2024-4-14 16:00:47 来自手机 | 显示全部楼层
2237663 发表于 2024-04-12 18:25:55 Inflatable lips, brillow pad hair, only seen at night if smiling are doing it.
","text":"And it doesn’t matter if your trailer is locked. They’ll break it off. Usually a group of 4 or more people.  This is happening every night in areas I mentioned. You would think the police would set up a sting operation and arrest these thieves. If this happens to you don’t approach the thieves. Call 911 and keep your doors locked.","replyToPid":480033}
发表于 2024-4-16 09:16:16 来自手机 | 显示全部楼层
842845 发表于 2024-04-14 08:00:47 And it doesn’t matter if your trailer is locked. They’ll break it off. Usually a group of 4 or more people.  This is happening every night in areas I mentioned. You would think the police would set up a sting operation and arrest these thieves. If this happens to you don’t approach the thieves. Call 911 and keep your doors locked.
","text":"yeah park out away from these places where normal good citizens live.","replyToPid":480045}
GMT+8, 2026-2-5 13:17 , Processed in 0.055547 second(s), 24 queries .
