查看: 61|回复: 5
What is the best internet SIM card company for truckers
 楼主| 发表于 2024-4-8 13:08:16 来自手机 | 显示全部楼层 |阅读模式
发表于 2024-4-8 14:42:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"Well my company provides a T-Mobile cellular Tablet with Unlimited 5G which we run our logs thru with the Motive App and I use the hotspot to connect my Garmin Dēzl GPS to WiFi for live updates and weather and traffic ect. and I have a iPhone SE with T-Mobile service also and then I have a iPhone 14 Pro Max  with duel e-sims and I have Verizon & US Mobile service both on it which US Mobile runs off Verizon towers and in my opinion T-MOBILE is where it's at! The coverage is just about everywhere and it's always 5G  while Verizon stays on LTE mostly unless you are in a heavily populated area. T-Mobile has a home Internet deal that runs off their cellular network that works awesome that is portable and perfect for putting your own network with  high speed Internet in your truck you should check out or go with a Hotspot off your phone but either way good luck hope that helps! Stay safe","replyToPid":0}
回复 支持 2 反对 2
 楼主| 发表于 2024-4-28 02:34:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"Before I was have TMobile the internet coverage was good in Michigan but when i go outside Michigan specially to Texas the coverage is bad there slow internet right now I have Verizon it's good but not too much specially when i stop in truck stop very slow internet coverage","replyToPid":0}
发表于 2024-4-19 04:58:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"I was going to switch from Verizon to t-mobile for true unlimited data.  Called Verizon and got switched to a \"new\" plan that is true unlimited data.  Verizon has the best total coverage nationally, att being second with t-mobile being a distant 3rd.  out of those 3, only att doesn't offer a truly unlimited data package (from what I've been able to find out).  Personally, I have Verizon and got a friend to put a unlimited data Hotspot on their plan for me.  I always have good service now.  Also, I do also run a signal booster in my truck which really helps.","replyToPid":0}
发表于 2024-4-19 04:59:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"edit; Hotspot is t-mobile","replyToPid":0}
发表于 2024-5-3 22:18:01 来自手机 | 显示全部楼层
2199698 发表于 2024-04-18 20:58:30 I was going to switch from Verizon to t-mobile for true unlimited data.  Called Verizon and got switched to a \"new\" plan that is true unlimited data.  Verizon has the best total coverage nationally, att being second with t-mobile being a distant 3rd.  out of those 3, only att doesn't offer a truly unlimited data package (from what I've been able to find out).  Personally, I have Verizon and got a friend to put a unlimited data Hotspot on their plan for me.  I always have good service now.  Also, I do also run a signal booster in my truck which really helps.
","text":"Hey what’s the deal with the signal booster? What kind is it, how much , and where can I get one?","replyToPid":480096}
GMT+8, 2026-4-18 08:43 , Processed in 0.117087 second(s), 24 queries .
