查看: 79|回复: 9
Load Locks
 楼主| 发表于 2024-3-23 10:11:41 来自手机 | 显示全部楼层 |阅读模式
{"text":"So just curious, what are some ways to store load locks if you don’t have a trailer, I know that you can get racks for them but let’s say I don’t have one, what could I do?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2024-3-24 09:44:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"Put them on your cat walk and ratchet strap them down","replyToPid":0}
发表于 2024-3-24 11:39:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you have a Pete or Kw you can put them under the bunk. Or behind the sleeper in between the groves of the fairings.","replyToPid":0}
发表于 2024-4-23 23:29:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"2 choices. Strap them to the catwalk or snuggle them in the bunk at night.","replyToPid":0}
发表于 2024-3-31 11:32:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"when all else fails, grab 2 rubber straps... lay your load locks across your catwalk and strap them to  the quarter fenders","replyToPid":0}
发表于 2024-3-25 23:10:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"well if you can slide them together some will fit in the side compartment or break them in half they should fit under the bunk house","replyToPid":0}
发表于 2024-3-24 08:07:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"Bungi Straps and a bit of prayer that they will stay where you strapped them down.","replyToPid":0}
发表于 2024-4-21 23:20:24 来自手机 | 显示全部楼层
2381721 发表于 2024-04-09 18:33:12 Yeah got a pack of sturdy rubber straps and tied them to it. Seems to hold well
","text":"Keep in mind that strapping them to your catwalk is a DOT violation.","replyToPid":480006}
发表于 2024-3-27 04:31:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"I had to put one behind the seats slanted","replyToPid":0}
 楼主| 发表于 2024-4-10 02:33:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yeah got a pack of sturdy rubber straps and tied them to it. Seems to hold well","replyToPid":0}
GMT+8, 2026-4-15 11:46 , Processed in 1.235487 second(s), 24 queries .
