查看: 24|回复: 13
Is there away around donner’s pass, there’s this huge storm from today til Sunday and I need to be LBC Cali by Friday…
 楼主| 发表于 2024-3-1 09:50:51 来自手机 | 显示全部楼层 |阅读模式
发表于 2024-3-2 04:11:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Well evidently I can't put in a link to a good weather website or Trucker Path censors the entire post. 🤦‍♂️\n\nSo go to a weather website provided by the US government. Its weather dot golf Oscar victor. Good site for lower 48 weather warnings.\n\nThe entirety of Nevada is under Blizzard warning, winter storm warning, winter weather advisory or high winds.\n\nBlizzard in Donner pass extends south somewhat and north. South is less worse than north. HWY 50 is in the Blizzard Warning DO NOT USE 50!  There are wind warnings all the way down to the Mexico border.","replyToPid":0}
发表于 2024-3-2 13:53:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Sit the storm out and reschedule is always best. No load is worth doing more miles or going through hazardous weather.","replyToPid":0}
发表于 2024-3-1 20:52:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"after trucking for 50 years my old old old man advice is it is better to sit March blizzards out then sneak around them.  \n\nstay warm","replyToPid":0}
发表于 2024-3-1 10:59:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"Only way I know is to run the southern route and then go up","replyToPid":0}
发表于 2024-3-4 03:37:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"What did you end up doing?","replyToPid":0}
发表于 2024-3-3 12:07:43 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"No park and wait or chain up and go for it.  you only do it once. Then you learn to wait.\nor drop down to 40 an add an extra day to the trip."}
发表于 2024-3-1 11:25:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"that's 1200 miles in less than 24 hours. are you driving a rocket? you might need to reschedule on that one. sorry. I like the NOAA app although the government has messed up storm warning a few times this year. imagine that. you'll need to check the weather on the southern passes to see if a 150 mile add in is worth it to you.","replyToPid":0}
发表于 2024-3-2 06:15:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"you can take 95 south past Hawthorn to the 360/6..that takes you to 395..then south to 58...takes you to bakersfield..or wait / chain up","replyToPid":0}
发表于 2024-3-1 14:13:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"hwy 50","replyToPid":0}
 楼主| 发表于 2024-6-9 06:36:10 来自手机 | 显示全部楼层
1126416 发表于 2024-03-03 19:37:19 What did you end up doing?
","text":"Drove back into Nevada for a lil bit and to Route/Hwy 95 south and made the the connections where I needed to go","replyToPid":479394}
发表于 2024-3-2 04:02:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"Not far enough south. HWY 50 is still in the Blizzard Warning area.","replyToPid":479338}
发表于 2024-3-3 01:26:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"Don't do it, wait the storm out.","replyToPid":0}
GMT+8, 2026-2-5 09:10 , Processed in 0.106966 second(s), 24 queries .
