查看: 16|回复: 7
Hey I got question for you guys running DD15.
 楼主| 发表于 2024-2-15 07:35:20 来自手机 | 显示全部楼层 |阅读模式
{"text":"I have a friend looking to buy a Coronado with DD15. How many miles can you get on it?  Common problems?  I don't know anything about detroit.  I only run cummins.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2024-2-19 08:36:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"In my opinion a DD15 is a solid engine. If you do your oil changes under 25k with semi synthetic and keep up on maintenance that engine can last up to 1 million. You will need to do the occasional overhead. Of course it will depend on the driver and the condition the last driver left it in.","replyToPid":0}
发表于 2024-3-1 06:32:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"I had a 2009 Cascadia I ran until 1,165,000. Then traded it in last year. You will probably have some oil leaks at the cam frame, & cylinder head gaskets. EGR cooler usually has to get replaced, and injector cup O-rings I had to get around 850,000 I think it was. I bought that truck with 650,000 miles, it was already bastardized mostly. it could have been different if I would have got it new. I changed oil every 15-18k miles.","replyToPid":0}
发表于 2024-2-22 05:59:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"Sensor issues as with a lot of freightliners as for Detroit, extremely reliable I think the best in industry I have the SD122 kinda looks like a smaller coranado I luv it like the classic look","replyToPid":0}
发表于 2024-2-22 03:50:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"i got a 2013 with dd15 love it barely any problem  maintain it well solid engine quiet . I always use a lucas with my oil change The main problems with the freightliners are always electrical the wires connector","replyToPid":0}
发表于 2024-2-20 06:33:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"I've seen many dd15 go a million and some before rebuild, if taken care of properly. 50k mile oil changes is ridiculous and engine won't last running like that. Tuned up they can run really hard. I'd rather have a 60 series. imo","replyToPid":0}
发表于 2024-2-15 10:58:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just buy a cascadia then tbh","replyToPid":0}
发表于 2024-3-1 06:33:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"DD15 yo","replyToPid":0}
GMT+8, 2026-2-5 14:55 , Processed in 0.059534 second(s), 24 queries .
