查看: 61|回复: 6
Starter companies in Illinois
 楼主| 发表于 2024-2-15 01:12:12 来自手机 | 显示全部楼层 |阅读模式
{"text":"New driver here with about 2 months of experience driving a Class A. I’m struggling to find a local place to work. Any ideas?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2024-2-15 21:55:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"2 months you're still wet behind the ears my friend you should have stuck with your job You're not going to go for making rookie pay to big dollars in 2 months get one to two years under your belt than anybody will hire you","replyToPid":0}
发表于 2024-2-19 08:38:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"You will have better luck if you put in 6 months plus OTR then call around for local jobs. With rates so low, capacity high, and low volume it might even be tough with 6 months OTR. That is not what you want to hear but it is honest. Good luck.","replyToPid":0}
发表于 2024-2-15 07:10:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"sorry that is so little experience. Hard to get on somewhere decent\ngonna have to go swift, jb hunt, Schneider etc.... gonna need at least a year to get a good place.\nyou may find a small 3-9 truck fleet that might take the risk. good luck.","replyToPid":0}
发表于 2024-2-15 10:59:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"Try private small companies near elk grove village there is a ton just ask around","replyToPid":0}
发表于 2024-3-1 06:34:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Those Frauds at FAB EXPRESS are pretty desperate, give Jerry a call","replyToPid":0}
发表于 2024-3-1 06:35:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Or go ask CHINATOWN on the truckers report, he is a know it all who likes to find companies for inquiring drivers","replyToPid":0}
GMT+8, 2026-4-15 11:46 , Processed in 0.097716 second(s), 25 queries .
