查看: 93|回复: 9
interested inquire?
 楼主| 发表于 2024-2-6 06:25:59 来自手机 | 显示全部楼层 |阅读模式
{"text":"I have an unusual question. I would like to move on with my current work situation. Are their situations where a pickup truck and a trailer are a thing? if this is something that is possible I would like to make a living from it.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2024-2-6 11:18:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes, its called hotshot trucking. Still have to follow all the trucking rules but equipment costs would be considerably lower.\n\nThat about exhausts my knowledge on the subject. 🤷🏻‍♂️","replyToPid":0}
回复 支持 6 反对 0
 楼主| 发表于 2024-2-7 09:57:23 来自手机 | 显示全部楼层
665190 发表于 2024-02-06 03:18:30 Yes, its called hotshot trucking. Still have to follow all the trucking rules but equipment costs would be considerably lower.\n\nThat about exhausts my knowledge on the subject. 🤷🏻‍♂️
","text":"I looked into it a little. basically if I'm just doing under 26,000 lbs. which I will. no cdl needed. just a dot","replyToPid":479035}
发表于 2024-2-13 01:31:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Two years ago “hot shots” were everywhere. Now, I barely see any out there. There must be a reason they are leaving.","replyToPid":0}
发表于 2024-2-8 21:40:31 来自手机 | 显示全部楼层
{"replyToPid":479049,"replyTo":"
2358999 发表于 2024-02-07 01:57:23 I looked into it a little. basically if I'm just doing under 26,000 lbs. which I will. no cdl needed. just a dot
","text":"I thought it was 25,000 but yeah if you're under the weight limit you don't need a CDL unless you have a trailer longer than some limit(25ft?).\n\nAlso, even with no CDL requirement you might need to still follow hours of service rules."}
发表于 2024-2-11 07:36:31 来自手机 | 显示全部楼层
665190 发表于 2024-02-08 13:40:31 I thought it was 25,000 but yeah if you're under the weight limit you don't need a CDL unless you have a trailer longer than some limit(25ft?).\n\nAlso, even with no CDL requirement you might need to still follow hours of service rules.
","text":"This is true, my buddy runs a hotshot business and runs an ELD, and does the DOT drug test. He’s out of Utah and they have him run an ELD not sure if every state requires it","replyToPid":479058}
 楼主| 发表于 2024-2-7 06:18:10 来自手机 | 显示全部楼层
","text":"thanks I'll look into it","replyToPid":479035}
发表于 2024-2-14 12:13:34 来自手机 | 显示全部楼层
1401340 发表于 2024-02-12 17:31:41 Two years ago “hot shots” were everywhere. Now, I barely see any out there. There must be a reason they are leaving.
","text":"My guess would be freight rates.","replyToPid":479101}
发表于 2024-2-15 07:11:24 来自手机 | 显示全部楼层
65688 发表于 2024-02-14 04:13:34 My guess would be freight rates.
","text":"exactly","replyToPid":479118}
 楼主| 发表于 2024-2-18 23:24:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"thanks everyone.  so on the truckload app you can actually filter for hotshot. I only have a 6x9 trailer so I'll be limited in the beginning.  but worth for what I'm trying to do.","replyToPid":0}
GMT+8, 2026-4-15 11:46 , Processed in 0.106706 second(s), 25 queries .
