查看: 21|回复: 15
How ya all liking those automatics no more shifting
 楼主| 发表于 2024-1-31 10:48:52 来自手机 | 显示全部楼层 |阅读模式
{"text":"I myself prefer shifting but I see lots trucks no more shifters is that a good thing or what.... specially with the heavy loads...... automatic quit engine brake on 6 gear already I’m used to down shifting minimum 3rd gear had to use more brakes..... might be costly on brake pads 🥵🥵🥵","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
1万
发表于 2024-1-31 19:31:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don't like them... the last company I worked for had a truck with a automatic transmission and it was constantly messing up, would not go into drive when you were ready to leave, it spent many days back at the dealer... plus I don't like it when starting on a hill it shifts to next gear only to either come to a complete stop or having to downshift back to the lower gear. next complaint is driving on slippery roads, it might downshift and put you in a slide. I don't like them at all, learn to shift like a pro...\n 🙂 🇺🇸 👍","replyToPid":0}
回复 支持 10 反对 0
发表于 2024-1-31 19:45:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don't like them. My company only gives us eco mode. It likes to shift up while I'm climbing a hill after already downshifting to compensate for the hill climb. I can manually down shift, but it doesn't stay locked in gear like manual mode does.","replyToPid":0}
回复 支持 7 反对 1
1万
发表于 2024-1-31 20:47:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"another problem with automatics is... if you are ever stuck in snow ( or mud or stone ) you can not \"rock\" yourself out like you can with a manual transmission... \n 🙂 🇺🇸 👍","replyToPid":0}
回复 支持 6 反对 0
发表于 2024-2-2 23:50:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"My worn out left knee probably would appreciate one. But I'm an operator. I need to feel everything on the truck. So manual transmission always for me.","replyToPid":0}
发表于 2024-2-11 02:29:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"I used to hate them but they get better every year in 5 more years or so the autos will be better than the manual trucks and the only reason to own a manual truck will be the same as a car just for fun","replyToPid":0}
发表于 2024-2-1 13:15:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don't like them at all. Cheap trucks if you're buying though and they're pumping out so many worthless drivers that's why companies are buying them. because it's harder for them to rip our clutches, fly wheels, gears,","replyToPid":0}
发表于 2024-2-2 22:48:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"I like mine. It had a learning curve, but once you know how to use it, there’s more control in low traction situations. Now if I can just train my foot to quit searching for the clutch when I’m coming to a stop…","replyToPid":0}
发表于 2024-2-1 12:38:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hi \nTo add to this , \nEaton has added this to there new ultra shift , \n(Which it’s not called that anymore) \nThey have somehow managed to add that feature of being able to \n‘Rock’!!\n\nJust like with ur manual","replyToPid":0}
发表于 2024-3-13 09:00:45 来自手机 | 显示全部楼层
1405493 发表于 2024-03-08 21:06:41 Well I think if you’re not hauling more the 80,000 the automatic is fine, especially if you’re in or near large cities. However if you’re hauling heavy or oversized then the automatics will never cut it. But, having family members who have been truckers 40+ years, the automatics definitely save you knee trouble and rotator cuff trouble in the long run.
","text":"Grossing 139,000 pounds if converted in Canada , \nNo issues . \n\nCan eat manual trucks on big hills , \nRed lights no problem ,","replyToPid":479466}
发表于 2024-2-2 21:54:01 来自手机 | 显示全部楼层
322465 发表于 2024-02-01 05:15:36 I don't like them at all. Cheap trucks if you're buying though and they're pumping out so many worthless drivers that's why companies are buying them. because it's harder for them to rip our clutches, fly wheels, gears,
","text":"If you spec a eaton ultra shift 18 speed \nVs 18 manual \n\nUr $8 more , with the ultra shift , \nMated to a x15 \nDeleted , its overall great","replyToPid":478946}
GMT+8, 2026-2-5 17:13 , Processed in 0.079651 second(s), 24 queries .
