查看: 21|回复: 14
I want to pass on some valuable information.
 楼主| 发表于 2024-1-25 20:26:00 来自手机 | 显示全部楼层 |阅读模式
{"text":"Few days ago there was a accident near my home. Driver pulls off on side of road in a wide spot. To nap at 5am in morning.  A 4 wheeler comes flying up and drives right into back of the trailer. The driver of car got killed. The police charge truck driver with list of charges.  For parking on side road.  Biggest charge was homicide.  My thought what was the driver of 4wheeler doing? He can't see  a parked truck?  I see many trucks parked on side of road or on get on ramps. When you do this. Your putting yourself in same position as driver I described.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2024-1-26 00:16:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"that's very unfortunate but proper planning will place you in the right place to rest... and so he put his self in that position.","replyToPid":0}
回复 支持 6 反对 3
发表于 2024-1-29 17:59:30 来自手机 | 显示全部楼层
2355241 发表于 2024-01-25 16:16:03 that's very unfortunate but proper planning will place you in the right place to rest... and so he put his self in that position.
","text":"What is that? Proper planning? Cause there has been plenty of times that I’ve planned my trips to avoid putting myself in situations where I have to make up a parking spot. But hold up let me guess….if all you do is sit behind a desk and make up rules of course you’d say that. Truck stops need  more truck parking that trucks obviously.","replyToPid":478872}
回复 支持 8 反对 0
发表于 2024-1-27 00:41:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"I never pull onto the side of a roadway unless I have to. if I'm gonna park anywhere near an active road it will be an ONRAMP where at least civilians aren't going at full speed if they miraculously manage to hit you. and that's almost a last resort. I can't stand parking at the big corporate truck stops but there are a million mom and pop biz out there you just have to look and they don't fill up by 1500. I agree with dude that proper trip planning could've avoided this situation. Id also add never underestimate the recklessness and/or straight state of oblivion that is a common trait among most automobile operators. if they can find a way to die they will. avoid them at all costs.","replyToPid":0}
回复 支持 6 反对 1
发表于 2024-1-27 18:10:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you gotta park somewhere like that always park on the on ramp not the exit ramp or on the side of\nThe highway . Brain dead move to take a 10 on the side of the road","replyToPid":0}
回复 支持 5 反对 1
发表于 2024-2-10 01:47:43 来自手机 | 显示全部楼层
97489 发表于 2024-01-29 09:59:30 What is that? Proper planning? Cause there has been plenty of times that I’ve planned my trips to avoid putting myself in situations where I have to make up a parking spot. But hold up let me guess….if all you do is sit behind a desk and make up rules of course you’d say that. Truck stops need  more truck parking that trucks obviously.
","text":"35 yrs out here trucking and parking has always been a problem","replyToPid":478904}
发表于 2024-1-27 13:56:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"man that is so terrible. I never pull over on side of road unless it's a complete emergency even then I will limp it of possibly to a better spot. off or on ramps last resort. I almost always find a good spot. you just have to trip plan. knowing how to use split sleeper when loads take a long time will help you not panic park.","replyToPid":0}
发表于 2024-1-26 03:39:28 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"That's 2 bad on loss of life. The trucker is always at fault no matter what. look what they did to Warner. I see so many driver pull over to do 30 minute break on side of freeway and some pull out from dead stop. I have had that happen many times. More truckers will be charged even more often."}
发表于 2024-1-28 02:56:31 来自手机 | 显示全部楼层
2135824 发表于 2024-01-27 10:10:00 If you gotta park somewhere like that always park on the on ramp not the exit ramp or on the side of\nThe highway . Brain dead move to take a 10 on the side of the road
","text":"I do pull over to side of the road when I have to pee and cannot hold it to a rest stop.  I hate it but what can you do?","replyToPid":478883}
发表于 2024-1-28 09:02:40 来自手机 | 显示全部楼层
1523276 发表于 2024-01-27 18:56:31 I do pull over to side of the road when I have to pee and cannot hold it to a rest stop.  I hate it but what can you do?
","text":"It’s called a pissjar you can dump it on the fly 😆","replyToPid":478886}
发表于 2024-2-10 01:49:36 来自手机
{"replyTo":"","text":"Put your triangles out and emergency flashers on, then manslaughter is off the table. B lazy and go to prison","replyToPid":0}
支持 1 反对 0
发表于 2024-1-27 13:07:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"Omg! That is awful …","replyToPid":0}
GMT+8, 2026-2-5 19:05 , Processed in 0.103273 second(s), 24 queries .
