查看: 129|回复: 5
Trucker Path features
 楼主| 发表于 2024-1-23 08:42:14 来自手机 | 显示全部楼层 |阅读模式
{"text":"Is there a way to see how much fuel I’m going to need for a trip in this app? I see it gives me tolls, but what about the fuel?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
1万
发表于 2024-1-23 18:04:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"take the miles for the trip and divide it by your miles per gallon...\n 🙂 🇺🇸 👍","replyToPid":0}
回复 支持 6 反对 0
发表于 2024-1-23 23:30:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"I second Mr Freeze. That's the most reliable way. I always use 5mpg as an average and easy calculation. If you're getting more than 5mpg you're doing great and will always have enough fuel. If you're getting less, you'll know because your truck is probably running badly. I have an older truck so I don't have experience calculating DEF mpg","replyToPid":0}
发表于 2024-1-23 23:30:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"So for example, a 250 mile trip would be 250 / 5 = 50, so get 50 gallons for that trip.","replyToPid":0}
 楼主| 发表于 2024-1-29 01:22:32 来自手机 | 显示全部楼层
1031233 发表于 2024-01-23 10:04:45 take the miles for the trip and divide it by your miles per gallon...\n 🙂 🇺🇸 👍
","text":"Thank you 😊","replyToPid":478829}
 楼主| 发表于 2024-1-29 01:22:48 来自手机 | 显示全部楼层
1090613 发表于 2024-01-23 15:30:55 So for example, a 250 mile trip would be 250 / 5 = 50, so get 50 gallons for that trip.
","text":"Thank you 😊","replyToPid":478831}
GMT+8, 2026-4-15 10:05 , Processed in 0.073065 second(s), 24 queries .
