查看: 52|回复: 3
Danger Of Truck Catching Fire
 楼主| 发表于 2024-1-16 18:31:33 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hello y’all. \n\nI have since shut the power off to the truck, prior to that, my truck was not running. And my head light looked like strobe light, lights were off, truck was off. \n\nMy question, even with the power cut to the truck, any danger of an electrical fire. 5:30 am, asking here is my only recourse.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
 楼主| 发表于 2024-1-20 19:09:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thank you, our mechanics are off site, and nobody relays information to the drivers. Not sure if it’s fixed yet, got my boots and pants ready if I need to exit quickly.","replyToPid":0}
发表于 2024-1-20 12:16:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"I had a 2016(I think) Freightliner that had a similar issue. I had used the cutoff switch but the lights kept rapidly flickering even with the power off.  It drained the battery if I recall(it was several years ago). \n\nClearly the master cutoff doesn't cutoff all power. If there's electricity running through a circuit there is a potential for fire. No way to qualify the danger though. It would depend on how much current is flowing and what it's flowing through.","replyToPid":0}
发表于 2024-1-19 21:09:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"pray about it","replyToPid":0}
GMT+8, 2026-3-23 01:04 , Processed in 0.073326 second(s), 24 queries .
