查看: 155|回复: 10
Done with this app!!!
 楼主| 发表于 2023-11-26 03:39:57 来自手机 | 显示全部楼层 |阅读模式
{"text":"I paid a ludicrous amount of money for the diamond version and now I wish I had not listened to people's recommendations about how great this app is. it's NOT! It's a Google product. Long story short, it directed me through a residential neighborhood on windy, curvy, hilly roads and a 25,000 pound weight limited bridge (I was grossing 76,000+) with no possible way to turn around or back up. There is an actual truck route to the place I was going to. How can they call this \"Truckers Path\"?????","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2023-11-26 04:02:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"Your not only person complaining about App. I bet 100 in last year. I personally use Garmin.","replyToPid":0}
发表于 2023-11-28 03:38:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can ask for google maps or Apple Maps..also you need to choose truck route not car route and write your trucks length high weight… if you dont it goes you through the closer route","replyToPid":0}
发表于 2024-3-17 03:38:39 来自手机
{"replyTo":"","text":"Who would be dumb enough to give these gooks money","replyToPid":0}
支持 2 反对 0
发表于 2023-11-27 09:22:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"this is not a  truck GPS is Google  map be careful .","replyToPid":0}
发表于 2023-11-29 21:14:39 来自手机 | 显示全部楼层
1671123 发表于 2023-11-27 19:38:50 You can ask for google maps or Apple Maps..also you need to choose truck route not car route and write your trucks length high weight… if you dont it goes you through the closer route
","text":"Yes, must make sure on your vehicle before setting off.","replyToPid":477929}
发表于 2023-11-29 21:20:30 来自手机 | 显示全部楼层
2239963 发表于 2023-11-25 20:02:12 Your not only person complaining about App. I bet 100 in last year. I personally use Garmin.
","text":"I’ve been using trucker path for over 7 years to check my truck routing. The only place I’ve had a problem with is all the low bridges in Chicago, but I know they are working on getting them in the system","replyToPid":477912}
发表于 2023-12-1 05:46:16 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Now you can’t check the path it is taking you on, unless you have began the trip. TP used to be my go to over my Garnin. The other night TP tried taking me where no trucks belong. They should get their issues fixed before everyone bails out."}
发表于 2023-12-3 06:26:27 来自手机 | 显示全部楼层
","text":"How i put high weight","replyToPid":477929}
发表于 2023-12-9 23:08:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"try a trucker GPS, Garmin is good","replyToPid":0}
发表于 2023-12-16 13:49:33 来自手机 | 显示全部楼层
503867 发表于 2023-12-09 15:08:28 try a trucker GPS, Garmin is good
","text":"Garmin is not too good on its own. I use 3 and Garmin is always trying to send you on longer routes because they have bad info. \nExample: My company has a yard in PA. The road that approaches the cross street is a huge 4 lane, but Garmin always tries to route you around the last 5 miles because there's a sign saying no trucks over 40ft at a grocery store entrance. It has nothing to do with the main road. At least once a week, I ignore the Garmin because the other 2 are in agreement of a shorter route. Once you pass a certain point, Garmin updates the route and matches the other 2. Its only good for finding rest areas and  truckstops with the voice feature, but that part of it is SORELY outdated. Sometimes, it doesnt show truckstops that have been there 50 yrs.","replyToPid":478070}
GMT+8, 2026-4-17 02:15 , Processed in 0.151554 second(s), 25 queries .
