查看: 14|回复: 9
What is going on with Truckers Path?
 楼主| 发表于 2023-11-16 10:23:47 来自手机 | 显示全部楼层 |阅读模式
{"text":"What is going on with this APP? I've never had any issues till today! They keep changing it and making it worse! Why fix something that isn't broken! We are paying all this money to get use of the best services the APP has yet it always changing! This morning like every morning for 3 years I put in an address I need to go to and I'm giving route options to take. I'm going to a location I've been to before and was given 3 route options to choose from, but tonight it's only giving me one option and that's not the way I want to go. Please fix this issue and stop changing the look of the app. Nothing was wrong with the original look!","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2023-11-17 04:15:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"I agree. It was working just fine before this last update a few days ago. Makes no sense. ","replyToPid":0}
发表于 2023-11-17 10:06:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"The exit numbers are not showing up on mine the last 2 days","replyToPid":0}
发表于 2023-11-17 08:41:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"I thinks it looks good, but one issue was; it was telling me to get off the i10 and then get back on-on the next on ramp -_-","replyToPid":0}
发表于 2023-11-16 11:50:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"You’re using an outdated version. You will need to uninstall the app, then install it again. ","replyToPid":0}
发表于 2023-11-19 06:33:18 来自手机 | 显示全部楼层
1080694 发表于 2023-11-17 00:41:45 I thinks it looks good, but one issue was; it was telling me to get off the i10 and then get back on-on the next on ramp -_-
","text":"This has happened with every app and gps unit I've used.","replyToPid":477796}
发表于 2023-11-19 08:42:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"Mine stopped announcing downhills and weigh stations with all updates. The maps do look nicer tho. ","replyToPid":0}
发表于 2023-11-19 09:01:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"look into who owns the app that will tell you everything you need to know.","replyToPid":0}
发表于 2023-11-21 13:35:20 来自手机 | 显示全部楼层
1345450 发表于 2023-11-19 00:42:10 Mine stopped announcing downhills and weigh stations with all updates. The maps do look nicer tho.
","text":"Mine too","replyToPid":477849}
发表于 2023-11-22 18:53:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"besides it freezing when you need most. stops working in a big city","replyToPid":0}
GMT+8, 2026-2-5 18:49 , Processed in 0.088134 second(s), 24 queries .
