查看: 56|回复: 3
trailer rental
 楼主| 发表于 2023-11-8 10:06:04 来自手机 | 显示全部楼层 |阅读模式
{"text":"I haven't been on here or anywhere for awhile but wanted to ask this and hopefully help others. I recently rented a trailer in which the agreement is signed as a lease, guess no other rental forms. I was told the trailer was ready anf waiting for me. When I got there we had to look for it and of course it wasn't ready. There was debri that needed cleaned out, lights weren't working, had a couple tires that needed replaced, and needed a paper plate cause they said they were waitingfor the plate. 4 hrs later I was on my way. Well, I am renting it weekly due to only needing it for a special contract and told them 2 weeks before the paper plate expired to send the permanent cause I was going to need it longer. It ended up taking several more calls before I finally, nearly 2 weeks after the paper plate expired, I got the permanent. Oh but wait, it gets better. The guy who deals with the plates is who I finally talked to to get it straightened out and was told it was supposed have a permanent plate already on it. I was never told that. I just found out the other day when I went to put the new plate registration in the holder on the trailer that the inspection is over due and the last one wasn't even filled out correctly. I informed them and said that I have a mechanic coming to look at it cause I believe there are some brake issues, which they said was fine, and that I am not able to use it due to the inspection. He asked if I could bring it to them, mind you they are several states away and it has mechanical issues and invalid inspection, and I said no. Once the mechanic looks at it and they decide what to do I'll be able to use it again. My big question now is am I entitled to any compensation due to there negligence of proper maintenance and not getting me the plate to keep running without a hiccup? The agreement is signed as a lease which states I would be liable for main, but with it being a weekly rental I would assume it's still on them. I am going to talk with my attorney tomorrow, but thought I'd post it here. I will add what my attorney says later.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2023-11-9 12:00:09 来自手机
764614 发表于 2023-11-09 01:29:48 From what I know so far it's a stretch for being legit since it's tailored for a lease not a rental. Today after talking more with an old trucker friend I found that they could be in deep for allowing the trailer to even leave there lot.
","text":"Sue em for 5 million ","replyToPid":477723}
支持 1 反对 0
发表于 2023-11-8 20:35:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"Can't help you without reading the lease contract. You should have actually read it through instead of just signing it","replyToPid":0}
 楼主| 发表于 2023-11-9 09:29:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"From what I know so far it's a stretch for being legit since it's tailored for a lease not a rental. Today after talking more with an old trucker friend I found that they could be in deep for allowing the trailer to even leave there lot.","replyToPid":0}
 楼主| 发表于 2023-11-9 09:30:54 来自手机 | 显示全部楼层
2237663 发表于 2023-11-08 12:35:25 Can't help you without reading the lease contract. You should have actually read it through instead of just signing it
","text":"I replied but did it as a comment. Didn't realize it till it posted","replyToPid":477722}
GMT+8, 2026-4-18 12:08 , Processed in 0.097108 second(s), 24 queries .
