查看: 16|回复: 9
Peterbilt Fan Cycling
 楼主| 发表于 2023-11-5 11:07:15 来自手机 | 显示全部楼层 |阅读模式
{"text":"Ok first post and not trying to start a argument over this or offend anyone...\n\nWhy are some trucks so noisy when the engine fan cycles on and off? Serious question. When I'm looking for a spot at the stops I always try to avoid parking beside certain makes because of it. Also, are these brands that much better on fuel the drivers can afford to let them idle all night? When it's mild outside I just cannot wrap my head around this. Obviously if it's really hot or cold outside it makes more sense...but how the heck do you sleep with that fan rattling your teeth every time it comes on?\n\n Again, serious questions not trying to pick a fight  or start a discussion over which is the best truck on the lot, etc. \n\nThanks for your feedback. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2023-11-6 06:07:44 来自手机
{"replyTo":"","text":"I use an app called sleep sounds play rain forest through the truck speakers, I don’t care what’s parked next to me reefer loud cat engine I sleep like the dead ","replyToPid":0}
支持 3 反对 0
发表于 2023-11-5 22:18:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"some of it depends on if a/c or defrost is on(uses a/c), will cycle the fan more.  Also depends on idle rpm, need rpm up so oil pressure gets oil to the top end.  Things like insulation inside the hood, how far forward is the engine, engine maker.  Just a few thoughts.  As for idling when temp is decent, could be one is running lots of powered items inside so not draining batteries, others well they aren't paying the fuel bill so they just don't care.  \n\nDrive safe, have a good day!","replyToPid":0}
发表于 2023-11-10 03:13:10 来自手机 | 显示全部楼层
1024394 发表于 2023-11-05 14:18:45 some of it depends on if a/c or defrost is on(uses a/c), will cycle the fan more.  Also depends on idle rpm, need rpm up so oil pressure gets oil to the top end.  Things like insulation inside the hood, how far forward is the engine, engine maker.  Just a few thoughts.  As for idling when temp is decent, could be one is running lots of powered items inside so not draining batteries, others well they aren't paying the fuel bill so they just don't care.  \n\nDrive safe, have a good day!
","text":"Your answer was very informative. Thanks","replyToPid":477698}
发表于 2023-11-6 21:09:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"You're not alone bud. I always try to park away from Peterbilts and reefers. I avoid parking at truck stops like the plague. Even with my motor running, I can't sleep next to these things. I park on ramps overnight or at Walmarts for a 34","replyToPid":0}
发表于 2023-11-6 01:58:06 来自手机
{"replyTo":"","text":"Mind over matter lmao! You just get use to the surrounding noises and if you do this as long as I have you probably will be half deaf anyway! Lol","replyToPid":0}
支持 2 反对 0
发表于 2023-11-6 23:51:50 来自手机
{"replyToPid":0,"replyTo":"","text":"Only one thing wakes me up: it's not  hurricanes,, bombing raid sirens, really really tan chubbywomen arguing over a midget! It's only when my Reefer shuts off. Sounds like your elog is forcing you to sleep when your not ready."}
支持 1 反对 0
49
1万
发表于 2023-11-6 21:34:37 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"those Big Engines can be scary\n 😰👻🎃👻😰\n     🙂 🇺🇸 👍"}
发表于 2023-11-9 11:00:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"Really?  Today's  truck are much quieter than older trucks idling.   Get yourself some ear plugs if fan coming on terrifying","replyToPid":0}
GMT+8, 2026-2-5 18:18 , Processed in 0.066546 second(s), 24 queries .
