查看: 65|回复: 9
Trying to get gas for my truck.
 楼主| 发表于 2023-10-13 06:30:55 来自手机 | 显示全部楼层 |阅读模式
{"text":"Do I have to lift the handle on the pump every time? ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
 楼主| 发表于 2023-10-14 09:03:53 来自手机 | 显示全部楼层
1661594 发表于 2023-10-14 00:12:45 No sit on it and cry i need gas someone will help you
","text":"I don't understand","replyToPid":477341}
回复 支持 1 反对 4
发表于 2023-10-14 08:12:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"No sit on it and cry i need gas someone will help you ","replyToPid":0}
发表于 2023-10-13 12:15:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"the handle is actually a back up pump for if the power goes out you can manually pump it 😏🤔","replyToPid":0}
发表于 2023-10-15 23:51:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ask Alexa or Siri n stand close to the pump then wait 10 minutes and the gas should already be in ur truck. Takes a few minutes for gauge to show full but u should be gud till ur next fill up!","replyToPid":0}
发表于 2023-10-13 09:29:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"it should rise on its own","replyToPid":0}
发表于 2023-10-20 04:03:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"nah, just use a rubber hose, that should do the trick","replyToPid":0}
发表于 2023-10-16 06:17:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"You have to lift then lower it up and down till your tank is full ","replyToPid":0}
发表于 2023-12-30 00:06:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"Lmao","replyToPid":477343}
发表于 2023-12-30 00:07:15 来自手机 | 显示全部楼层
493141 发表于 2023-10-15 15:51:06 Ask Alexa or Siri n stand close to the pump then wait 10 minutes and the gas should already be in ur truck. Takes a few minutes for gauge to show full but u should be gud till ur next fill up!
","text":"Lmao","replyToPid":477362}
GMT+8, 2026-4-18 10:42 , Processed in 0.118047 second(s), 24 queries .
