查看: 18|回复: 4
would you build your home over a sewage treatment plant? see that anywhere?
 楼主| 发表于 2023-10-11 13:41:03 来自手机 | 显示全部楼层 |阅读模式
{"text":"so why am I parking 100000 dollars worth of equipment in human waste? would you set up your own bed over another person's waste? how well would you sleep? so I'm not sure why you think your kids' breakfast cereal belongs marinating in your soup of disease but I found two dead rats this last week at two different ts. notice the bins are moving closer to the building. have some personal pride. I have not had a clean parking spot in a month. if I show up as a tech to a waste filled spot I will refuse to crawl under your vehicle. they should refuse that. it's very distasteful. why are \"health certified \" people struggling with this? you're the healthy sanest ones. act like you don't belong institutioned. geez. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2023-10-11 21:45:03 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"This can also apply to sweeping trailers out in the lot. You would think they wouldn’t leave nails, screws, sharp bits of metal in their own driveway for their significant other or children to drive over. I could be wrong though."}
发表于 2023-10-11 21:40:35 来自手机 | 显示全部楼层
{"replyToPid":477297,"replyTo":"
678033 发表于 2023-10-11 05:46:06 even the Amish put their outhouse away from the building so stop wading through it. it's not okay to dump your pot right out the door. there is no street sweeper going to fix that and have of America is in a drought. not even the almighty is fixing it for you.
","text":"I agree with you 100 percent. A friend of mine who passed away fairly recently worked as a welder at a driveline shop. He refused to work on any truck where there was a hole cut in the floor of the cab due to the waste that was accumulated underneath."}
 楼主| 发表于 2023-10-11 13:46:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"even the Amish put their outhouse away from the building so stop wading through it. it's not okay to dump your pot right out the door. there is no street sweeper going to fix that and have of America is in a drought. not even the almighty is fixing it for you.","replyToPid":0}
GMT+8, 2026-2-5 21:27 , Processed in 0.075523 second(s), 24 queries .
