查看: 78|回复: 3
Hey guys my trailer are not sliding dandom I brake pad are check from mechanic change air connector still not working
 楼主| 发表于 2023-10-8 09:19:29 来自手机 | 显示全部楼层 |阅读模式
发表于 2023-10-8 23:44:15 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Make sure all the pins are retracting. Sometimes one of more pins will get \"stuck\". You can sometimes free it by rocking between forward and reverse.  If one or more pins won't retract no matter what you do it probably needs to go to a trailer repair shop.\n\nIf the pins are retracted but the tandems won't slide try lubricating the rail with WD40 or similar. \n\nMake sure the tandems line up in the same position on both sides. If the left side is in position 2 but the right is in position 3 the tandems are probably jammed. You need to fix that or the trailer will track off to the left or right possibly out of your lane. That's not only dangerous it will wear out the trailer tires pretty fast."}
发表于 2023-10-8 21:09:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"your pins might be stuck or broken or needs to be greased.  have someone check all of that","replyToPid":0}
发表于 2023-10-19 05:27:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"Have a hammer sound like a pin problem, walk around beat all four pins sometimes they get locked up, loves has some awesome spray on them then rock back forth they come un Stuck","replyToPid":0}
GMT+8, 2026-3-21 08:13 , Processed in 0.114350 second(s), 24 queries .
