查看: 108|回复: 12
suggestions
 楼主| 发表于 2023-9-25 00:05:55 来自手机 | 显示全部楼层 |阅读模式
{"text":"Anyone know if there is something like a suggestion form or something for trucker path? Needs to be a option to adjust the speed you can go.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
1万
发表于 2023-9-25 00:49:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"speed adjustment is on your cruise control...\n 👍 🇺🇸 🙂","replyToPid":0}
发表于 2023-10-11 11:02:13 来自手机 | 显示全部楼层
1068068 发表于 2023-09-26 10:22:54 Trucker path doesn’t have the option to set your top speed. You have to use Hammer or TDP for that
","text":"Top Speed? an 7 to 8 % grade and Total weight of 80,250 top speed can be achieved, now I have a Extended Hood Cabover, and that's fun","replyToPid":477046}
发表于 2023-9-26 18:22:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"Trucker path doesn’t have the option to set your top speed. You have to use Hammer or TDP for that","replyToPid":0}
发表于 2023-9-27 14:28:35 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Most likely he means he want to turn the beeping off when he is speeding. Not an option on an app to control his speed. Good gawd. "}
发表于 2023-9-27 21:58:21 来自手机 | 显示全部楼层
1401340 发表于 2023-09-27 06:28:35 Most likely he means he want to turn the beeping off when he is speeding. Not an option on an app to control his speed. Good gawd.
","text":"Probably means to set the maximum governed speed for the navigation function.","replyToPid":477063}
发表于 2023-9-25 07:44:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"your foot is your speed adjustment, there's no app for that lol lol lol","replyToPid":0}
发表于 2023-9-27 05:51:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Do you not know how to control throttle yourself?","replyToPid":0}
发表于 2023-9-28 10:35:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don't compute?","replyToPid":0}
发表于 2023-9-29 09:56:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"www.thetruckersreport.com","replyToPid":0}
发表于 2023-10-11 10:59:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"OMG, I've cussed them out at Least 3 times a week, but I do know how to read a Driver's Atlas, I do know how to plan a route and I look the situation over before I make a tight turn, low clearance (I've seen some not marked) I don't care if i am holding up the 4 wheelers. they'll get over it","replyToPid":0}
GMT+8, 2026-4-18 13:46 , Processed in 0.110968 second(s), 24 queries .
