查看: 196|回复: 15
Tandems
 楼主| 发表于 2023-9-18 04:25:47 来自手机 | 显示全部楼层 |阅读模式
{"text":"When sliding tandems to get to 6th hole do you can’t from the first hole thts open or all the holes from the beginning even the plugged ones?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2023-9-18 17:02:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"I only count from the the stop bar. Haven’t had a problem in over 15 years.  ","replyToPid":0}
回复 支持 4 反对 1
发表于 2023-9-19 13:29:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"You include the plug hole in your count.","replyToPid":0}
发表于 2023-9-22 11:01:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"if its a permanent trailer scale it a few times. you will know where u want it after that.","replyToPid":0}
发表于 2023-9-27 05:46:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"I start with the hole after the stop bar as well.","replyToPid":0}
发表于 2023-9-30 12:34:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"don't count anything but the open holes","replyToPid":0}
发表于 2023-9-22 13:07:51 来自手机
{"replyToPid":0,"replyTo":"","text":"buttt plug?"}
支持 0 反对 1
发表于 2023-9-30 12:36:56 来自手机 | 显示全部楼层
264491 发表于 2023-09-30 04:34:40 don't count anything but the open holes
","text":"right 👍","replyToPid":477103}
发表于 2023-9-30 12:37:16 来自手机 | 显示全部楼层
","text":"right","replyToPid":477103}
发表于 2023-9-30 12:37:56 来自手机 | 显示全部楼层
2267781 发表于 2023-09-26 21:46:39 I start with the hole after the stop bar as well.
","text":"well done driver","replyToPid":477052}
发表于 2023-9-30 12:41:09 来自手机 | 显示全部楼层
229979 发表于 2023-09-18 09:02:45 I only count from the the stop bar. Haven’t had a problem in over 15 years.
","text":"works for me also 🙂","replyToPid":476936}
GMT+8, 2026-4-17 08:58 , Processed in 0.097946 second(s), 24 queries .
