查看: 139|回复: 7
brakes locked tires will not move. air is hissing out of trailer knob
 楼主| 发表于 2023-9-17 08:32:54 来自手机 | 显示全部楼层 |阅读模式
发表于 2023-9-17 12:55:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"Check your airlines and gladhands for possible holes or leaks ","replyToPid":0}
回复 支持 4 反对 1
发表于 2023-9-17 09:42:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"bad valve","replyToPid":0}
发表于 2023-9-23 10:06:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"check to make sure air lines are on coreect gladhands","replyToPid":0}
发表于 2023-9-21 00:34:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"Did you get the problem resolved ","replyToPid":0}
发表于 2023-9-23 05:40:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Air leak is causing trailer spring brakes to deploy.\n\nYou'll only be able to drag the trailer until that's fixed. Insufficient info to say where. First thing is check the glad hand seals. That's a $5 fix that takes 5 minutes.","replyToPid":0}
发表于 2023-10-7 11:50:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you get under the trailer with a 9/ 16th socket and ratchet.. you can loosen your breaks where they won't drag.. just to get you to a repair shop. and remember to tell them to readjust the brakes.","replyToPid":0}
发表于 2023-10-11 11:11:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"yep, sounds like trouble is a-brewing","replyToPid":0}
GMT+8, 2026-4-15 10:04 , Processed in 0.099069 second(s), 25 queries .
