查看: 30|回复: 13
Anyone using a grease less 5th wheel? What's pros and cons?
 楼主| 发表于 2023-9-13 01:04:34 来自手机 | 显示全部楼层 |阅读模式
 楼主| 发表于 2023-9-14 02:55:37 来自手机 | 显示全部楼层
1644529 发表于 2023-09-13 16:36:27 I'd suggest adding a slick disk to the trailer rather than going with a \"greesless\" fith wheel. Should be easier to maintain.
","text":"Thanks for input. Gives me something to think about","replyToPid":476885}
发表于 2023-9-14 00:36:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'd suggest adding a slick disk to the trailer rather than going with a \"greesless\" fith wheel. Should be easier to maintain.","replyToPid":0}
发表于 2023-9-14 00:33:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"Mechanic and driver here. They are great until the greaseless nylon (or whatever dang plastic they are made of) pads wear out. Theoretical, they are easy to replace. However, in the real world, you often end up breaking multiple torq bits and / or break off several of the fasteners in the fith wheel. The fasteners are difficult to extract once the head breaks off.","replyToPid":0}
 楼主| 发表于 2023-10-24 19:24:08 来自手机 | 显示全部楼层
2237663 发表于 2023-10-22 22:53:53 Works great if you don't change trailers. If you pull different trailers they wear out fast.
","text":"Thanks for input.  I own my trailer. so I very rarely drop it.","replyToPid":477518}
发表于 2023-9-18 07:19:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"How off should you grease the fifth wheel ?","replyToPid":0}
发表于 2023-10-21 18:27:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have a greaseless plate and I still use grease just out of habit","replyToPid":0}
发表于 2023-10-23 06:53:53 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Works great if you don't change trailers. If you pull different trailers they wear out fast."}
 楼主| 发表于 2023-9-13 15:12:33 来自手机 | 显示全部楼层
332591 发表于 2023-09-13 01:58:27 I use a slick 5th wheel plate from Minimizer obviously it’s much cleaner also my trailer seems to turn more smoother and the overall ride has improved..my two pennies on the subject 🚶🏾‍♂️\n
","text":"I appreciate feedback","replyToPid":476877}
发表于 2023-9-13 09:58:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use a slick 5th wheel plate from Minimizer obviously it’s much cleaner also my trailer seems to turn more smoother and the overall ride has improved..my two pennies on the subject 🚶🏾‍♂️\n","replyToPid":0}
发表于 2023-9-13 04:39:13 来自手机
{"replyToPid":0,"replyTo":"","text":"This is some real bot questions...something you ask when you're real lonely..."}
支持 0 反对 1
GMT+8, 2026-2-5 18:17 , Processed in 0.077191 second(s), 24 queries .
