查看: 133|回复: 13
What's wrong with this picture?
 楼主| 发表于 2023-9-7 03:25:05 来自手机 | 显示全部楼层 |阅读模式
{"text":"Truck next to me at the truck stop this morning. ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":1512.0}]","canComment":true,"externalShare":false}
发表于 2023-9-9 05:01:05 来自手机
{"replyTo":"","text":"what's wrong is that you notice something wrong, and instead of talking with the individual you see the problem with, you share it online to fulfill your need to feel superior.  Did I get it right?","replyToPid":0}
支持 2 反对 3
41
发表于 2023-9-8 20:12:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"Lines are touching the catwalk.","replyToPid":0}
发表于 2023-9-9 07:05:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"your heads not under that tire","replyToPid":0}
发表于 2023-9-8 21:50:07 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Is that a snake?  or taped up lift gate cord? They should not be on the deck like that. That is how a fire is started."}
发表于 2023-9-9 03:48:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"it's a typical Volvo operator, that's the problem with this photo","replyToPid":0}
 楼主| 发表于 2023-9-10 18:00:46 来自手机 | 显示全部楼层
{"replyToPid":476739,"replyTo":"
925557 发表于 2023-09-08 12:12:46 Lines are touching the catwalk.
","text":"Correct, good way to break the air lines or pig tail.\n\nBreak the red airline and the trailer spring brakes come on and the trailer tires skid. Bad enough at low speed; a potential disaster at high speed.\n\nBreak the blue airline and the trailer will still roll but you'll only have tractor brakes. You won't have trailer brakes at all."}
 楼主| 发表于 2023-9-10 23:33:25 来自手机 | 显示全部楼层
{"replyToPid":476811,"replyTo":"
2237663 发表于 2023-09-10 13:06:47 Ok never heard of that before.
","text":"You'll only sometimes see it in a reefer truck. I used to pull a reefer trailer for a company that specialized in food hauling. Most of their older trucks used an electric bunk heater/cooler.\n\nI lucked out in never having an electric bunk heater. I guess the newer Freightliner I had later had one but it used \"smart idle\" and the truck's engine to recharge it as needed."}
发表于 2023-9-10 05:49:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"Auxiliary lights not mounted properly?","replyToPid":0}
发表于 2023-9-10 09:02:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’m wondering if you brought it to the drivers attention? ","replyToPid":0}
 楼主| 发表于 2023-9-10 17:51:58 来自手机 | 显示全部楼层
1571942 发表于 2023-09-10 01:02:41 I’m wondering if you brought it to the drivers attention?
","text":"Tried to 🤷🏻‍♂️","replyToPid":476793}
 楼主| 发表于 2023-9-10 17:56:10 来自手机 | 显示全部楼层
2237663 发表于 2023-09-08 13:50:07 Is that a snake?  or taped up lift gate cord? They should not be on the deck like that. That is how a fire is started.
","text":"The taped up cord is for an electrical bunk heater/cooler.  Some reefer trucks use the reefer engine to power the bunk heater.","replyToPid":476741}
GMT+8, 2026-4-17 16:50 , Processed in 0.140321 second(s), 24 queries .
