查看: 69|回复: 7
Hi 😊how do I try to avoid mountain driving on routes in app? Thanks!! I looked around in settings but couldn’t find
 楼主| 发表于 2023-9-2 20:58:38 来自手机 | 显示全部楼层 |阅读模式
发表于 2023-9-3 02:26:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"why do you want to avoid mountain driving? In parts of the country, especially the west you can't really avoid it.","replyToPid":0}
回复 支持 5 反对 1
发表于 2023-9-3 07:46:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"Don’t avoid them. Jakes are your friend in good weather and going slow with higher rpms in the winter. Gravity is not your friend. ","replyToPid":0}
发表于 2023-9-8 10:08:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"There is absolutely no reason to avoid mountain driving if you’re going to drive a truck. Be patient, remember that you can go down too slow a million times but only once too fast. Take your time, stay off your brake, and just let everyone go around you on the way down. Pay attention to the signage posted on the highway and always stop at the brake check areas and make sure everything is good before descending no matter how fair the weather. Biggest advice, relax. You can do anything you set your mind too! Don’t let the CB bigots get at you!","replyToPid":0}
发表于 2023-9-3 06:58:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"Not possible.  Mountains on east coast and bigger mountains on west coast.","replyToPid":0}
发表于 2023-9-3 04:13:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"Can’t avoid it because some of those routes are the fastest way through the mountain region. Also depending on where you are it’s the safest due to semi truck limitations throughout the city limits ","replyToPid":0}
发表于 2023-10-11 11:34:07 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"mountains can be intimidating, but just take yer time. stay OFF the brakes, let your Jakes walk ya down"}
发表于 2023-10-17 10:45:56 来自手机
{"replyTo":"","text":"get a job at mcdonalds","replyToPid":0}
支持 1 反对 0
发表于 2023-9-8 07:11:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"Stay in Midwest and south and you never have to worry.","replyToPid":0}
GMT+8, 2026-4-15 13:31 , Processed in 0.108302 second(s), 24 queries .
