查看: 69|回复: 5
hwy 277 texas
 楼主| 发表于 2023-8-28 05:59:45 来自手机 | 显示全部楼层 |阅读模式
{"text":"Is there a truck restriction in carrizo spring Texas on hwy 277 off of hwy 83? GPS says there is, but atlas does not list it. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2023-8-29 23:25:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"I believe there is truck restriction follow the signs, don’t listen to people on here","replyToPid":0}
回复 支持 4 反对 1
发表于 2023-8-29 06:34:38 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"GPS is a tool and it's not perfect.\n\nI have a Garmin DEZL and it will tell me a road is restricted when it isn't.  \n\nI bought a Rand McNally with points because the Gamin's truck routing was so bad. The Rand McNally isn't any better.\n\nYou CAN trust the paper road atlas as long as it's current."}
发表于 2023-8-28 06:19:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"no restrictions.  I run it all the time","replyToPid":0}
发表于 2023-9-1 07:02:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"cannot take hwy directly thru town to Eagle Pass. need to take the loop/bypass off 83 at north end of town.","replyToPid":0}
发表于 2023-10-11 11:36:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"and this is a VERY good Example of why a GPS can't be trusted but a driver's atlas don't charge in the middle of the route","replyToPid":0}
GMT+8, 2026-3-21 04:41 , Processed in 0.103846 second(s), 24 queries .
