查看: 58|回复: 3
Hazmat Route
 楼主| 发表于 2023-8-23 08:30:25 来自手机 | 显示全部楼层 |阅读模式
{"text":"Does this app have a Hazmat setting for routes?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2023-8-23 16:41:09 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Yea. When u put your destination, before pressing navigate, press the settings gear button on top right. Below, where it shows optimized routing option, you’ll see “Truck 1 manage,” press that & scroll to the bottom. There you’ll see the hazmat options. This is also where u manage all your truck info like axle weight, etc. Don’t forget to go back & put “none” when you aren’t pulling hazmat or you’ll be going hazmat routes when doing regular dry van"}
发表于 2023-8-24 00:24:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes use the gear ","replyToPid":0}
发表于 2023-10-11 11:39:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"yep. what he said above me the Mountain Man there 🖕","replyToPid":0}
GMT+8, 2026-4-15 15:31 , Processed in 0.100305 second(s), 25 queries .
