查看: 100|回复: 7
Best CB radio to get and why
 楼主| 发表于 2023-8-20 00:31:11 来自手机 | 显示全部楼层 |阅读模式
{"text":"Title. Thanks for your help ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2023-8-21 20:47:35 来自手机 | 显示全部楼层
665190 发表于 2023-08-20 13:47:34 🤷🏻‍♂️ Any CB and decent antenna will transmit a few miles which is all you need.\n\nIf you want someone to talk to get a dog.
","text":"The CB is for talking. You’re a 🤡","replyToPid":476382}
回复 支持 4 反对 1
发表于 2023-8-20 21:47:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"🤷🏻‍♂️ Any CB and decent antenna will transmit a few miles which is all you need.\n\nIf you want someone to talk to get a dog.","replyToPid":0}
发表于 2023-8-20 06:59:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"Galaxy DX66v3, Stryker655 or 955. All three are great radios and have excellent receive and talking capabilities ","replyToPid":0}
发表于 2023-8-21 12:22:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"There is not really a simple answer for this question . Best basic radio would be Cobra 29 ltd. They are durable and on the low end of the price range. If you’re looking to shoot skip or talk with local base stations. You will need something a little more. I Personally use a RCI/ Ranger 69vhp. Clean audio and a bit more power. But still low enough energy draw that it can be used with regular power hookups in your truck. But the most important part is the antenna system. Make sure it is tuned for your truck. Or it could cause damage to your radio.","replyToPid":0}
发表于 2023-8-20 03:21:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"cobra","replyToPid":0}
发表于 2023-8-20 07:44:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ranger 292 ","replyToPid":0}
发表于 2023-8-21 00:44:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have a President Richard works very well, go to a CB shop of some reputation Bobs on I 80 exit 70 he is very good and have them install radio new coax and a decent antenna will make all the difference in the world.","replyToPid":0}
GMT+8, 2026-3-21 14:30 , Processed in 0.088460 second(s), 24 queries .
