查看: 12|回复: 5
Drivers how often does your truck regen? This cummins wants to regen more than my detroit did. I drive and idle it same
 楼主| 发表于 2023-8-14 20:18:22 来自手机 | 显示全部楼层 |阅读模式
发表于 2023-8-15 00:34:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"needs diag computer to see if it is completing the regen. or if ash count is too high, temp range too low, 7th injector not spraying correctly etc.....","replyToPid":0}
发表于 2023-8-18 07:48:50 来自手机 | 显示全部楼层
1337475 发表于 2023-08-16 13:11:48 if they are ran hard they Regen more, best way to clean them out it to run it light and higher rpm while doing regen
","text":"Sorry, that's not accurate. If you're talking about a Cummins, they like heat. The best thing is to run the engine under heavy load. Not light.","replyToPid":476284}
发表于 2023-8-16 21:11:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"if they are ran hard they Regen more, best way to clean them out it to run it light and higher rpm while doing regen","replyToPid":0}
发表于 2023-8-14 21:01:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"Nothing beats a Detroit, mine barely regenerated, now I have Paccar regens more often for sure","replyToPid":0}
发表于 2023-8-18 06:52:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"I drive an International with a Cummins engine. It seems to regen a lot more than the Freightliner I used to drive.","replyToPid":0}
GMT+8, 2026-2-5 21:27 , Processed in 0.078881 second(s), 24 queries .
