查看: 13|回复: 4
prime get your truck fixed
 楼主| 发表于 2023-8-11 21:19:39 来自手机 | 显示全部楼层 |阅读模式
{"text":"if you're getting told to slow down for fuel efficiency at Prime, bring your truck for inspection. it took me three inspections to find my stuff. there's no way I would know some of these fixes. I was at the bottom on fuel efficiency and not the top for speed. ultimately it was a loose drag link, a shifted torque arm and a needed alignment and new drive tire. (three inspections on the new tire too. haha)  what's the spec for the torque arm? I don't even know. it was slightly out of spec. not non compliance. so now because I fixed the truck I'm safe and my loaded mpg is running about 9.8 climbing mountains. that would be close to the reported number they pump out. don't just slow down. it doesn't always help. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2023-8-12 00:52:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"Those items has nothing to do with fuel efficiency","replyToPid":0}
回复 支持 6 反对 0
发表于 2023-8-12 09:44:52 来自手机
{"replyToPid":476185,"replyTo":"
2232562 发表于 2023-08-12 01:43:21 This comment has been deleted
","text":"*You're.  You stewpid fukk"}
支持 1 反对 2
发表于 2023-8-12 23:16:20 来自手机
{"replyToPid":476188,"replyTo":"
2209430 发表于 2023-08-12 01:44:52 This comment has been deleted
","text":"* Eres una mierda racista borracho."}
支持 1 反对 1
发表于 2023-8-12 09:40:05 来自手机
{"replyTo":"","text":"what a dumb broad.","replyToPid":0}
支持 1 反对 1
74
发表于 2023-8-12 02:30:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"if you don't know how to address fuel efficiency and only know how to mash the pedal, you don't belong in a CMV, they teach you that in cdl school, you should know how to correct the problems on your own, I teach all my students everything that will properly keep that truck running at the lowest costs for repairs","replyToPid":0}
发表于 2023-8-12 09:43:21 来自手机
{"replyToPid":476183,"replyTo":"
2209430 发表于 2023-08-12 01:40:05 This comment has been deleted
","text":"Your a drunk racist"}
支持 0 反对 1
发表于 2023-8-13 22:27:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"Great advice friend! These things all effect production. Stay safe.","replyToPid":0}
发表于 2023-8-20 05:03:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"I would just get the away from Prime. their trucks are a hazard on the road going that slow. I sure in the hell wouldn't drive for them.","replyToPid":0}
GMT+8, 2026-2-6 00:43 , Processed in 0.070766 second(s), 24 queries .
