查看: 132|回复: 12
53 foot trl
 楼主| 发表于 2023-8-8 07:38:12 来自手机 | 显示全部楼层 |阅读模式
{"text":"is it legal to run trl tandems all the way back to rear of trl","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2023-8-10 03:47:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"I keep one of mine all the way back at all times so no trailer swing. 😉\n\nI run flat, sd, lb, etc though. All joking aside, you shouldn’t run all the way back on van or reefer. Need to look at state laws for each individual state to see where your tandem placement is legal. ","replyToPid":0}
回复 支持 6 反对 0
发表于 2023-8-9 02:27:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"In some States it’s Legal Texas Kansas Oklahoma I’m sure more, Rand McNally trucker road maps have Info on every State weights lengths much more","replyToPid":0}
回复 支持 6 反对 0
发表于 2023-8-8 10:07:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"As far as I know that isn't legal on the road.","replyToPid":0}
发表于 2023-8-9 05:29:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"$100 fine in FL. 41' kingpin to center of trl. tandems.","replyToPid":0}
发表于 2023-8-10 03:33:57 来自手机 | 显示全部楼层
1068068 发表于 2023-08-09 08:52:07 Just out of curiosity, why would u want to drive with tandems all the way back?🧐
","text":"I’ve had to drive with them all the way to rear before to scale my axles legal heavy load of beer","replyToPid":476133}
发表于 2023-8-9 22:28:12 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I never do that once I'm empty, I slide them all the way forward just so I can get around the corners easier,  the only time they're all the way back is when I'm loading/unloading and that's it"}
发表于 2023-8-8 23:03:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"https://www.bigtruckguide.com/kingpin-to-rear-axle/","replyToPid":0}
发表于 2023-8-9 16:52:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just out of curiosity, why would u want to drive with tandems all the way back?🧐","replyToPid":0}
发表于 2023-8-11 23:11:16 来自手机 | 显示全部楼层
678033 发表于 2023-08-11 13:27:26 that's no legal in michigan. not California either. sometimea not indiana if its a state route. aren't rules fun? I hate being tucked in like that. I worry about too much tail swing.
","text":"tailswing is cheaper than dropping your axles in the ditch or running something/someone over","replyToPid":476167}
发表于 2023-8-18 07:52:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"Get a Rand McNally road atlas. They'll have the state by state legal dimensions for kingpin and bridge law. Good luck on those turns.","replyToPid":0}
发表于 2023-8-10 22:02:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s called the bridge-law look it up","replyToPid":0}
GMT+8, 2026-4-15 15:31 , Processed in 0.096950 second(s), 25 queries .
