查看: 380|回复: 33
Keep trucking ELD
 楼主| 发表于 2023-8-1 10:07:04 来自手机 | 显示全部楼层 |阅读模式
{"text":"Keep trucking ELD Is a complete joke for the trucking industry. They allow dispatch to edit your logs so you can run longer hours how is that compliant in any country. You are better of running paper i thought ELD would be better to get away from forced dispatch. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2023-8-3 17:01:17 来自手机 | 显示全部楼层
936953 发表于 2023-08-03 02:40:56 If you knew how to trip plan, they wouldn’t need to edit anything.
","text":"Trip planning has nothing to do with the illegal editing of logs that the OP is referring to. There are companies, many out of Chicago, who do edit keep trucking logs to keep you running illegally. Key word is illegally. Ya’ll super truckers acting like ya’ll have all the answers are a joke","replyToPid":476045}
回复 支持 5 反对 1
发表于 2023-8-1 20:41:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"all elogs are editable. no such thing as forced dispatch. Who has the key to the truck? Who signs the log at the end of the day?","replyToPid":0}
回复 支持 3 反对 3
发表于 2023-8-1 18:42:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'm never forced to run illegal, and my logs are never tampered with, I monitor my log every day, the only time they get edited is if the eld goes haywire and I request the assistance of getting it fixed properly, it's a felony of your dispatch is tampering with your log book and it also puts a very bad mark on the company, furthermore I would highly recommend that you do more homework on how the ELD actually works and find peace with yourself and enjoy life because in the end you don't get to keep anything \ncheers 🍻","replyToPid":0}
发表于 2023-8-1 23:57:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"It was my understanding that if a company has \"no forced dispatch \" it means they will allow you to turn down loads you do not want. so then I would guess forced dispatch would mean that you are required to go where they tell you when they tell you. personally I never turn down any load because I like money.\n\nIf what you are saying is actually happening then I would start keeping a paper log regardless, it is your responsibility to make sure your logbook is accurate. and then I would start looking for another job. now they could possibly put you on duty or off duty but I don't think it's possible to change the drive line, if the vehicle tells electronic log that the vehicle is in motion, I don't think anybody can change that which is why you see all these idiots creeping around the truck stops all the time.","replyToPid":0}
发表于 2023-8-1 11:29:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"nothing to do with forced dispatch you know nothing about the rules","replyToPid":0}
 楼主| 发表于 2023-8-4 06:18:30 来自手机 | 显示全部楼层
1068068 发表于 2023-08-03 09:01:17 Trip planning has nothing to do with the illegal editing of logs that the OP is referring to. There are companies, many out of Chicago, who do edit keep trucking logs to keep you running illegally. Key word is illegally. Ya’ll super truckers acting like ya’ll have all the answers are a joke
","text":"Finally someone who understands what I’m talking about ","replyToPid":476050}
发表于 2023-8-1 22:54:25 来自手机 | 显示全部楼层
766797 发表于 2023-08-01 03:29:36 nothing to do with forced dispatch you know nothing about the rules
","text":"Has everything to do with forced dispatch ","replyToPid":476009}
发表于 2023-8-22 03:45:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"They are known for this issue and the drivers saying you can't edit the info, you can. You just can't edit Drove Time. However, your carrier can.\nThis is a known issue by FMCSA and DOT. You may find the link to report it as well as additional information pertaining to HOS @ fmcsa.dot.gov","replyToPid":0}
发表于 2023-8-4 09:58:23 来自手机 | 显示全部楼层
{"replyToPid":476059,"replyTo":"
1243986 发表于 2023-08-03 22:18:30 Finally someone who understands what I’m talking about
","text":"Well if you declare “forced dispatch” as an official term, then you might as well declare “forced labor”…seriously. \n\nYes there are crazies at companies like TQL that just assume the drivers are made of metal alloy."}
发表于 2023-8-4 01:35:02 来自手机 | 显示全部楼层
2224992 发表于 2023-08-01 12:41:11 all elogs are editable. no such thing as forced dispatch. Who has the key to the truck? Who signs the log at the end of the day?
","text":"Tell everyone what company you work for?","replyToPid":476015}
 楼主| 发表于 2023-8-1 14:02:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you understood what I’m talking about you would know dispatch can play with the hours on your log and make you keep going. Just a FYI have a good day ","replyToPid":0}
 楼主| 发表于 2023-8-1 14:47:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"But I’d love to hear what you think forced dispatch is ","replyToPid":0}
 楼主| 发表于 2023-8-2 07:34:39 来自手机 | 显示全部楼层
1248444 发表于 2023-08-01 10:42:52 I'm never forced to run illegal, and my logs are never tampered with, I monitor my log every day, the only time they get edited is if the eld goes haywire and I request the assistance of getting it fixed properly, it's a felony of your dispatch is tampering with your log book and it also puts a very bad mark on the company, furthermore I would highly recommend that you do more homework on how the ELD actually works and find peace with yourself and enjoy life because in the end you don't get to keep anything \ncheers 🍻
","text":"I’m just saying that I have had that happen dispatch edits the logs and tells me to keep going. ","replyToPid":476014}
 楼主| 发表于 2023-8-2 07:36:00 来自手机 | 显示全部楼层
597174 发表于 2023-08-01 14:54:25 Has everything to do with forced dispatch
","text":"Exactly driver ","replyToPid":476020}
GMT+8, 2026-4-17 10:29 , Processed in 0.105840 second(s), 24 queries .
