查看: 56|回复: 3
Pre pass question
 楼主| 发表于 2023-7-27 00:57:13 来自手机 | 显示全部楼层 |阅读模式
{"text":"East cost of canada. Hot do I know if the pre pass is on? I know that the boat lights up to either report to scales or bypass but at some scales it doesn’t light up even if the scale is open","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2023-7-29 02:30:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have no idea how much the east cost?  \n$100?. yes it is hot!\nwhere are the boat lights?","replyToPid":0}
回复 支持 0 反对 3
发表于 2023-7-27 01:32:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"What ELD y’all running? If it’s Omnitrax, the issue is with them. Let dispatch now. ","replyToPid":0}
发表于 2023-7-28 08:21:59 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"If your PrePass doesn't give you a signal one way or the other pull in to the weigh station. You won't get in trouble for weighing when you didn't have to. You will be in trouble if you fail to stop when they wanted to weigh your truck.\n\nSometimes the scale house doesn't have PrePass or it may not be working."}
GMT+8, 2026-4-15 15:31 , Processed in 0.065400 second(s), 24 queries .
