查看: 63|回复: 4
semi truck CA147 Grass valley
 楼主| 发表于 2023-7-24 03:58:36 来自手机 | 显示全部楼层 |阅读模式
{"text":"Can a semi truck 48 ft trailer travel from Colfax to Grass valley California using CA-147  starting from I-80 exit 135. Randy McNally shows no restrictions caltrans map does not get too detailed. just want a second opinion.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
 楼主| 发表于 2023-7-25 11:04:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes I made it to Grass valley using CA147 there's a sign at the second right turn after you get off the freeway and enter 147, says kingpin to last axle 31 ft not advised,","replyToPid":0}
发表于 2023-7-24 21:39:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Did you make it?","replyToPid":0}
 楼主| 发表于 2023-7-24 14:41:36 来自手机
{"replyTo":"","text":"F it I'm going for it.","replyToPid":0}
支持 2 反对 0
41
发表于 2023-7-24 08:28:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"https://dot.ca.gov/programs/traffic-operations/legal-truck-access/quick-guide","replyToPid":0}
发表于 2023-7-28 03:12:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Good to know. I’m 53 ft. ","replyToPid":0}
GMT+8, 2026-4-15 15:20 , Processed in 0.122196 second(s), 24 queries .
