查看: 118|回复: 13
Hey brothers. I’m a new driver. My question is. Is it normal for my air lines to get ripped down. This is the second to
 楼主| 发表于 2023-7-22 02:07:47 来自手机 | 显示全部楼层 |阅读模式
发表于 2023-7-23 18:04:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"you need to fix it because the lines will fray if they keep rubbing on your truck when you drive.","replyToPid":0}
发表于 2023-7-22 06:44:21 来自手机 | 显示全部楼层
2219702 发表于 2023-07-21 22:26:25 where do u got your fifth wheel sitting
","text":"On the back of the truck ","replyToPid":475797}
发表于 2023-7-23 18:00:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"do you have a hanger. my company issued the wrong hanger with my truck and replaced it a while later. so apparently there are different sized wire hangers. they are springy and slide on the bar along the back. you can adjust the hanger too. there's a slide rubber clamp that will adjust along the line to change the tension. if you don't have a hanger you probably need one.","replyToPid":0}
发表于 2023-7-22 22:58:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Either your lines are too short, your 5th wheel is too far back, or you’re making your turns too tight. ","replyToPid":0}
发表于 2023-7-22 12:11:36 来自手机
{"replyTo":"","text":"Once saw a driver with a chocolate face , I can't remember what mega company. He was bobtail and parked next to me.  i told him his air lines was ripped off, and he said he knew.  Drove off dragging them on thw ground like it wasn't no shite.","replyToPid":0}
支持 1 反对 1
发表于 2023-7-22 09:36:05 来自手机
{"replyToPid":475802,"replyTo":"
2209258 发表于 2023-07-22 00:45:16 This comment has been deleted
","text":"That was his old name rętard"}
支持 2 反对 0
发表于 2023-7-22 08:45:16 来自手机
{"replyToPid":475799,"replyTo":"
2202915 发表于 2023-07-22 00:38:38 This comment has been deleted
","text":"You going to bend over for him? Sounds like that's your preference"}
支持 2 反对 0
24
发表于 2023-7-22 03:09:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"No.  probably need more slack so they have room to stretch when making turns","replyToPid":0}
发表于 2023-7-22 06:26:25 来自手机 | 显示全部楼层
1730426 发表于 2023-07-21 19:09:54 No.  probably need more slack so they have room to stretch when making turns
","text":"where do u got your fifth wheel sitting","replyToPid":475795}
发表于 2023-7-23 00:28:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Need to adjust your fifth wheel plate. It’s probably set too far forward. Get someone to video you making a very slow turn so they can walk along side you and video it. When your lines begin to start taking up the slack, stop. Get out, look at the video then look at the position of your fifth wheel. If you have room to move it so the trailer is closer to the cab, move it and do it again. It may take you a couple of ttys to be able to get through your turn without any of your slack taken away. If that does not work, check to see if the hose hangar is mounted correctly and at the right height. It might be too high or the lines may be wrapped around each other which shortens them. If these tips don’t fix your issue, you may need to get new lines. ","replyToPid":0}
发表于 2023-7-22 23:37:04 来自手机 | 显示全部楼层
586020 发表于 2023-07-21 22:44:21 On the back of the truck
","text":"No above the tires ","replyToPid":475798}
发表于 2023-7-23 03:27:50 来自手机 | 显示全部楼层
","text":"hello 👋"}
发表于 2023-7-23 03:28:48 来自手机 | 显示全部楼层
","text":"well mines all the way back because I have a Pete so it looks good but if I was in like a Volvo or cascadia I would have it slid more forward","replyToPid":475797}
发表于 2023-7-23 03:44:04 来自手机 | 显示全部楼层
1730426 发表于 2023-07-22 19:28:48 well mines all the way back because I have a Pete so it looks good but if I was in like a Volvo or cascadia I would have it slid more forward
","text":"but I also use the extra space to have equipment over  hang as well because I do flatbed","replyToPid":475819}
GMT+8, 2026-3-23 01:04 , Processed in 0.123435 second(s), 24 queries .
