查看: 62|回复: 5
Was at orientation for a job yesterday. I was in there with a bunch of veteran drivers that had nothing good to say.
 楼主| 发表于 2023-7-5 05:14:20 来自手机 | 显示全部楼层 |阅读模式
发表于 2023-7-6 03:55:24 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"veteran drivers at orientation?  They are lying or are bad drivers. The ones that complain are the the ones usually causing the problems they are complaining about."}
发表于 2023-7-6 03:41:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"A lot of negativity in the trucking industry, it’s what you make it. I’ve been trucking for 16 years and loving it gets easier & easier","replyToPid":0}
发表于 2023-7-13 19:32:04 来自手机 | 显示全部楼层
2202915 发表于 2023-07-05 19:55:24 veteran drivers at orientation?  They are lying or are bad drivers. The ones that complain are the the ones usually causing the problems they are complaining about.
","text":"J.j. I’ve been out here for 28 years, back in the day it was nothing but good times. It’s not that way anymore. Todays truckers are getting screwed!! Some companies don’t offer detention. They also don’t pay you if you’re sitting in traffic for an hour to four hours sometimes going to grocery warehouses it takes you 3 to 4 hours to get unloaded and you don’t get paid for it the rate per mile does not equal to a decent salary? Nobody cares about other drivers anymore. We use to all have C.B.’s and look out for one  another. And most of all you’re separated from your family, and sometimes that can lead to depression and or divorce. ","replyToPid":475552}
发表于 2023-7-14 03:24:54 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Focus on yourself man. If you don’t let yourself be distracted, while still being respectful, you can outwork your company and progress from there. \nDriving a truck takes too much mental energy to get swayed by negative thoughts. Everyone faces them."}
发表于 2023-7-14 00:47:44 来自手机 | 显示全部楼层
75861 发表于 2023-07-13 11:32:04 J.j. I’ve been out here for 28 years, back in the day it was nothing but good times. It’s not that way anymore. Todays truckers are getting screwed!! Some companies don’t offer detention. They also don’t pay you if you’re sitting in traffic for an hour to four hours sometimes going to grocery warehouses it takes you 3 to 4 hours to get unloaded and you don’t get paid for it the rate per mile does not equal to a decent salary? Nobody cares about other drivers anymore. We use to all have C.B.’s and look out for one  another. And most of all you’re separated from your family, and sometimes that can lead to depression and or divorce.
","text":"The whole scene if the world has changed nit just trucking","replyToPid":475658}
GMT+8, 2026-3-22 23:27 , Processed in 0.109198 second(s), 24 queries .
