查看: 90|回复: 8
Advice
 楼主| 发表于 2023-7-5 02:59:48 来自手机 | 显示全部楼层 |阅读模式
{"text":"So been hauling heavy equipment for about 2 yrs.Starting flatbed with a spread next week.Do you guys find your center?Some of this is gonna be new to me having to make sure it's loaded properly.Hauling mainly Brick,shingles and some pipe out of Houston steel yard","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2023-7-5 23:49:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"Pretty obvious he's talking about centering load.","replyToPid":0}
发表于 2023-7-5 08:26:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just loader up and go","replyToPid":0}
发表于 2023-7-5 09:33:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"center of what? the centerline of your trailer? If you're talking about the centerline, just get a tape measure and mark it off. Or measure the distance between 2 stake pockets then count them off to find center","replyToPid":0}
发表于 2023-7-8 05:39:50 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I liked to run weight over the tires not the center. \nwith a spread it's pretty easy to weigh legal. Remember more weight to rear."}
发表于 2023-7-5 21:19:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hi there everyone ","replyToPid":0}
发表于 2023-7-6 03:43:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"48’ or 53’ flatbed? It’s makes a big difference ","replyToPid":0}
发表于 2023-7-8 03:47:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"Depends on the length of your trailer, a 48’ Center is at the middle marker light, as for a 53’ trailer it’s the stake pocket in front of the middle marker light. I found out the hard way where centers where (cost me $).","replyToPid":0}
发表于 2023-7-10 21:37:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"On my trailer, turn signal is center ","replyToPid":0}
GMT+8, 2026-4-17 10:26 , Processed in 0.142345 second(s), 24 queries .
