查看: 129|回复: 13
First haul Idaho to Ohio
 楼主| 发表于 2023-6-6 14:17:32 来自手机 | 显示全部楼层 |阅读模式
{"text":"This is my first time hauling a trailer. Any suggestions as to routes that avoid high elevation climbs and steep downgrades along the way? ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2023-6-7 08:34:44 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I’ve always thought mountains are overrated. Nothing to worry about unless the pavement is slippery from ice and snow. Start out going slow down hill and use the number 3 position on the jake brake. Stay off your service brakes as much as possible. When you use the service brakes press hard on the pedal for three seconds at the most. Then let off the brakes and let the jake brake do the work. Never ride the service brakes going downhill. Slow down before a curve. Just play it safe and don’t worry about the super truckers passing you and going fast (that would be me 😂)!"}
1万
发表于 2023-6-7 05:31:39 来自手机 | 显示全部楼层
834116 发表于 2023-06-06 17:06:46 That is number one take your time and DONT be a super trucker right out of the gate. Wind in Wyoming can be brutal
","text":"Yes, don't be a super trucker, leave that to the professionals !!!\n 🙂 🇺🇸 👍","replyToPid":474945}
发表于 2023-6-7 01:06:46 来自手机 | 显示全部楼层
844021 发表于 2023-06-06 09:21:46 The only place you should have to worry about any significant climbs would be coming from Idaho to Cheyenne. You're not really gonna be able to avoid the mountain chain in that stretch regardless of route. Just take your time down the hills and you'll be good.
","text":"That is number one take your time and DONT be a super trucker right out of the gate. Wind in Wyoming can be brutal","replyToPid":474936}
发表于 2023-6-6 23:17:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"I-90 will certainly test you through Idaho and Montana it’s like 300 miles straight of up and down. I blew a fuel pump goin over them ","replyToPid":0}
发表于 2023-6-6 21:47:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"Your automatic transmission will do all the work for you. You will be fine.","replyToPid":0}
发表于 2023-6-6 17:21:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"The only place you should have to worry about any significant climbs would be coming from Idaho to Cheyenne. You're not really gonna be able to avoid the mountain chain in that stretch regardless of route. Just take your time down the hills and you'll be good.","replyToPid":0}
发表于 2023-6-9 17:50:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"Always park on the off ramp and rest stops first. I need to get a spot at the truck stop after work. Lol \n\nIt’s good to be openly concerned as a rookie. Ask a ton of questions, learn your map. Not the fancy electrical kind.. the Rand. Can’t call yourself a trucker if you need GPS. Don’t get me wrong, I like my gadgets. But I def can read/calculate routes with my map and don’t need gps to get home from anywhere.  ","replyToPid":0}
发表于 2023-6-7 08:10:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"don't stress, focus on your driving.  read the signs on the down hill speed limits and try to get confortable with the truck on down shifting b4 going down the hills and using the Jake break and don't smoke your brakes. watch the RPMS down hills.","replyToPid":0}
发表于 2023-6-7 02:12:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"Take the river route ","replyToPid":0}
发表于 2023-6-14 07:10:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"You Can't completely avoid mountains.\n1. Stick to the interstate. Slopes are rarely extreme on the interstates(there are some exceptions). \n2. Take it slow! You can go down a slope too slow many times. You can only go down too fast once.\n3. Generally the speed you go up a hill is the speed you want to go down. However, sometimes the opposite slope will be significantly different.\n4.  Assuming you have an automatic the cruise control should mostly maintain speed. If your RPM gets close to 2, 000 hit the service brake, slow down 5 or 10mph and reset the cruise to the new speed.\nDo NOT ride the brake!!! \nLet the engine do most of the braking.","replyToPid":0}
发表于 2023-6-8 11:33:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"Idaho, I84 to I 86 Pocatello  to I 15 McCammon to US 30 to I 80 Little America and I 80 to Ohio.","replyToPid":0}
GMT+8, 2026-4-15 13:48 , Processed in 0.130492 second(s), 24 queries .
