查看: 119|回复: 10
Shifted trailer/container to right
 楼主| 发表于 2023-5-24 23:49:20 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hi, \n\nHave any of you had this problem that truck and trailer are not in a straight line? \nI drive straight, keep to the left and I see in the mirror that the trailer is on the right line.\n\nSame problem with trailers and containers but not every time. What could be a problem? Trailer suspension? \n\nAny ideas ?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2023-5-26 04:38:00 来自手机 | 显示全部楼层
1248444 发表于 2023-05-25 16:46:52 7 words: operator error and lack of proper training
","text":"That's 8 words and a number","replyToPid":474788}
回复 支持 5 反对 2
 楼主| 发表于 2023-5-26 21:33:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"Solved.\nI spoke with mechanic.\nIf someone take a turns at high speed and with a heavy load this causes a hit tandem on axel. After that he has to set alignment using lasers. Cost 199$ ","replyToPid":0}
回复 支持 5 反对 1
发表于 2023-5-25 11:14:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"It's called a dog leg. The trailer wheels are out of alignment. It's usually caused when a driver hits a curb or something like that.","replyToPid":0}
发表于 2023-5-25 00:22:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Get the trailer aligned.    ","replyToPid":0}
发表于 2023-5-25 16:17:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"Adjust your tandems  it happens when tandems pin not in hole","replyToPid":0}
发表于 2023-5-26 00:46:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"7 words: operator error and lack of proper training","replyToPid":0}
发表于 2023-5-25 23:08:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"It happens a lot because when driver's do adjust the trl tandems the truck and trl are not aligned.  When the tandems move they twist (bend) the trl frame.","replyToPid":0}
发表于 2023-5-25 06:51:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"adjust your mirror","replyToPid":0}
发表于 2023-5-25 02:25:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Windy ?","replyToPid":0}
 楼主| 发表于 2023-5-25 02:51:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Seriously?","replyToPid":474741}
GMT+8, 2026-4-17 17:08 , Processed in 2.643922 second(s), 24 queries .
