查看: 42|回复: 3
Anyone know if todays blitz they are checking for deleted trucks?
 楼主| 发表于 2023-5-16 22:13:19 来自手机 | 显示全部楼层 |阅读模式
发表于 2023-5-16 23:04:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"This year I do believe focus is on ABS and load securement.  Obviously level 1 is everything so depends on where you are if they are able to check.","replyToPid":0}
发表于 2023-5-18 07:48:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Not DOT’s job to check for deleted trucks","replyToPid":0}
发表于 2023-5-16 22:57:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"Mostly checking ABS brakes, Lights on truck and trailer, air leaks, tires and rims, and E Logs history.","replyToPid":0}
GMT+8, 2026-3-21 08:12 , Processed in 0.093969 second(s), 24 queries .
